20th January 2022, 06:33 PM
#10171
Missing in Action
Mickhead
The money he charged you would think he was towing 2 vehicles.![](https://s3.amazonaws.com/tapatalk-emoji/emoji52.png)
Sent from my campfire using smoke signals.
The Following User Says Thank You to VK2FMIA For This Useful Post:
20th January 2022 06:33 PM
22nd January 2022, 04:08 PM
#10172
Packed up ready for camping at feral flats, doggies favourite camping spot 😋
The Following 3 Users Say Thank You to Stropp For This Useful Post:
Avo (22nd January 2022), MB (22nd January 2022), Woof (23rd January 2022)
23rd January 2022, 10:58 PM
#10173
I removed the acc socket in the rear cargo area and replaced it with a Narva amp meter. These single amp meters are on clearance from Repco for $16.
I had not used this socket once in the almost 3 years I have had it installed, so the amp meter will be more useful in it's space to monitor how much the fridge is drawing.
The Following 2 Users Say Thank You to Cremulator For This Useful Post:
jay see (24th January 2022), MB (24th January 2022)
3rd February 2022, 08:59 PM
#10174
Replaced my electric antenna insert that I broke on the feral flats trip, old age I forgot to drop it prior to doing the bush tracks, what a mission, had to remove the whole thing from the inner guard and then dismantle the motor and remove the tube the antenna sits in as even though the instructions say you can push it into the top, there is a small lip that prevents you doing that so after a struggle managed to remove the tube and feed the new one up and then set the gear teeth on the retractor and reassemble the motor then test prior to reinstall in the guard, surprisingly it works I forgot to take pictures
The Following 2 Users Say Thank You to Stropp For This Useful Post:
MB (4th February 2022), mudnut (3rd February 2022)
3rd February 2022, 10:59 PM
#10175
Stropp
Replaced my electric antenna insert that I broke on the feral flats trip, old age I forgot to drop it prior to doing the bush tracks, what a mission, had to remove the whole thing from the inner guard and then dismantle the motor and remove the tube the antenna sits in as even though the instructions say you can push it into the top, there is a small lip that prevents you doing that so after a struggle managed to remove the tube and feed the new one up and then set the gear teeth on the retractor and reassemble the motor then test prior to reinstall in the guard, surprisingly it works ������ I forgot to take pictures
Left it in the shed didn't let stropp drive it
The Following 4 Users Say Thank You to Avo For This Useful Post:
MB (13th February 2022), rusty_nail (5th February 2022), Stropp (5th February 2022), Woof (10th February 2022)
13th February 2022, 07:21 PM
#10176
The Following 3 Users Say Thank You to MB For This Useful Post:
Cremulator (13th February 2022), Plasnart (13th February 2022), Rossco (13th February 2022)
13th February 2022, 08:08 PM
#10177
Sway bar looks way fatter than standard Nissan setup, have you had much of a chance to see how she goes in the corners reckon Nissan one's are near on useless lol. . .
13th February 2022, 08:23 PM
#10178
Only a quick 5 minute spin around town so far Rossco but felt positively different for sure. Can’t make any comment on the front sway bar as yet but upgrading the rear springs from C45-123VT 200kg variable rate constant load feels shiploads less boaty now full of tools at under 10psi running upwards of 40-50 psi kevlar bagged floating on air only previously.
Rossco (14th February 2022)
13th February 2022, 08:53 PM
#10179
Breadmaker Shaker
MB
Grouse when you get springs to do suspension, not ask airbags to do suspension coz they dont. Work your springs; airbags just transfer force to chassis.
IMO
The Following User Says Thank You to Plasnart For This Useful Post:
13th February 2022, 09:08 PM
#10180
