29th January 2022, 02:35 PM
suspension lift/swaybars
Hi guys Poopsie here,on my 2016 ls3 patrol ,due to the two inch lift the sway bars are lifted as well.Does this cause handling problems on highway or is it only a problem off road.Obviosly I can fit longer links if I should.
Thanks again for all previous replies.
29th January 2022 02:35 PM
29th January 2022, 08:13 PM
Ideally the sway bars should sit flat to work perfectly in all situations
The Following User Says Thank You to Deano2506 For This Useful Post:
MudRunnerTD (30th January 2022)
30th January 2022, 09:50 PM
Moderator
Yeah as above mate. The arms should be flat and horizontal so your linkages should be the right length to set them up flat. This allows full flex in both directions. I have found rhe factory linkages to be pretty average and I have broken more than my fair share.
Superior Engineering make a Superflex arm which has longer arms that seem to work great and a good option for the front of a Patrol.
Check out my Toy -->
Rogue Dung Beetle
Hodge (1st February 2022)
31st January 2022, 09:55 PM
The Following User Says Thank You to MB For This Useful Post:
MudRunnerTD (1st February 2022)
1st February 2022, 06:42 AM
I've been suggested upgrading this magic superior sway setup several times.
Most notably when I fitted up the superior Panhard rod.
Is this what I'm looking at ? And is this mostly self plug and play, bolt off bolt on kind of install ?
https://www.superiorengineering.com....ont-only-21979
Sent using Pixel 6
1st February 2022, 05:20 PM
Moderator
Hodge
Sent using Pixel 6
Yes mate. those chassis plates bolt onto the side of the chassis using existing factory captured nuts. I bought a front one off Nicco when he stripped his GU and fitted it to Rufus. I didnt get to use it in anger but the quality was great and the extended arms make a lot of sense. @matfew now owns Rufus and may comment. Good kit i reckon.. If i was ever going to put sway bars back on the GQ t would be those.
Rogue Dung Beetle
