19th December 2021, 07:06 PM
Y62 warning lights
Recently purchased a Y62 series 5 Ti 4 months ago. After having it for 2 months we had an engine warning light come up on the dash. Called Nissan roadside assist who cleared the codes the we took it to a Nissan dealer who checked all the faults and said the battery was low and trickle fed the battery for the day. Everything was OK until a few days ago. Started car up, ran it for a minute, engine fan started coming on and off and then all the warning lights came on. Turned the car off then it would not restart at all. Left it for an hour and went back. Tried to restart but it just wound over. Tried again and it started but the only warning light now showing was the engine warning light. Plugged in the engine scanner to check codes (101), unplugged scanner and warning light disappeared. Took it to another nissan dealer who check the faults and everything passed. They tried to blame the accessories on the vehicle but we only have a redarc brake controller. Has anyone else had the same issues? Is it possible it could be something to do with the smart altinator not putting enough charge into the battery. It seems to happen when the vehicle has been sitting for a few days.
19th December 2021 07:06 PM
19th December 2021, 07:34 PM
@MudRunnerTD your all around the smart alternator crap on these aye?
The Following User Says Thank You to Avo For This Useful Post:
MudRunnerTD (20th December 2021)
19th December 2021, 08:34 PM
Avo
Not quite sure what you mean mate I'm only asking a question
20th December 2021, 06:51 AM
SPAMINATOR
Lambo07
He's tagging another bloke (@MudrunnerTD ) who's a bit of a whiz and knows stuff.
![](image.php?s=dbc13c4f4da2c585e81f4eacd83a160a&u=2058&type=sigpic&dateline=1604048275)
The Following User Says Thank You to growler2058 For This Useful Post:
20th December 2021, 10:07 AM
Moderator
Who installed the brake controller mate? Did you buy the car new? Sounds Odd. Either your Alternator is faulty. Shunt is playing havoc or the brake controller has a fault maybe. Head back to the dealer for sure. Keep a note and record all fault codes.
Check out my Toy -->
Rogue Dung Beetle
20th December 2021, 10:35 AM
Bought the vehicle new, the dealer fitted brake controller, the dealer reckons if it was the alternator it'll be throwing codes all the time, car goes back to the dealer in the new year.
The Following User Says Thank You to Lambo07 For This Useful Post:
20th December 2021, 08:37 PM
Moderator
Lambo07
Yeah OK. Well the good news is they cant blame an after market installer.
Assuming they used the Loom kit for the trailer plug its a plug and play. There is No Re-wiring for this fitments. It's a Plug and play loom which comes with a 20 page instruction manual on how to strip interior panels to find the relevant Loom plug. Child's play.
Keep pushing back mate, they will have to sort it. To be honest though it's not reasonable that you wait until the new year for a fault find on something that could leave you on the side of the road on Boxing Day! No Chance!! I'd be pushing hard direct to the Service Manager directly for action this week. Keep us in the loop.
Rogue Dung Beetle
20th December 2021, 08:46 PM
Moderator
I just re read your 1st post.
If it sits a few days and the battery is low then there is a stray current draw somewhere and a dealer will always blame an after market accessory for this but you have nothing that THEY did not fit. Their problem
The Alternator runs a Negative Shunt to drop the output after initial starting. I have removed this shunt to allow a full 14.5v continuous charging as I have a Lithium Cranking battery under the bonnet that needs 14.5v. You could unplug the shunt but this might open a door for the dealer to knock you back given its a direct charging fault.
It really isn't your job to figure this out, it is theirs. And Before Christmas thanks!!! Or ask the Service manager to swap cars with you for the period over Christmas New year and he can get stranded on the side of the road with his family instead of yours. Seriously that's what they are asking you to accept. You spent upwards of $85K with them. Their problem.
Rogue Dung Beetle
20th December 2021, 09:09 PM
22nd December 2021, 09:53 AM
Car has gone back to dealer who we bought from, working on the problem as I speak, the dealer is going to start a case with Nissan Australia, at the moment they can't find any new code they're not sure what's wrong, they have tested battery and alternator seems fine.
