1st December 2021, 09:25 AM
Travelling Podologist
Windscreen washer bottle - interchangeability between GU & GQ?
My windcreen washer bottle is leaking. Found yesterday that the bottle was empty. Refilled it & this morning MrsTea noticed a tell tale puddle under the car. Washer bottle is no longer full & observed a drip underneath along with wetness on the bottom of the bottle.
First thought was to remove it & repair the leak, but I suspect the chances of a repair working/lasting are not good, particularly given the sort of roads we drive on & a leak can only get worse. We use our washers quite a lot in the dusty conditions.
Having ascertained the silly money wanted for a genuine washer bottle I looked at the aftermarket options. Best price I can find is $71 (Single outlet ute version without pump).
I note however that in the pictures the bottles available for GQ's look like they are the same & are over 2/3rds cheaper at around $20 or low $30's with a fitted pump.
QUESTIONS: 1. Will GQ bottle fit straight into my GU like a GU one?
2. Anyone who has bought a replacement bottle without a pump - any problems fitting/sealing the old pump into a new bottle? ie. would I be better buying a bottle
with a pump (cheap aftermarket) fitted?
This link advertises a washer bottle for GQ & GU, suggesting the bottles are interchangeable up to 2007?? (mine is 2006).
1st December 2021 09:25 AM
1st December 2021, 09:44 AM
MrsTea's observation of the pics, honed from the sort of puzzles she likes doing, immediately noticed that the first pic in the post above (GU bottle) appears to have an indentation below & left of the filler cap, which doesn't show in the GQ bottle pics.
However I took a photo of my existing bottle - no indentation. Maybe mine is not a GU one, or an aftermarket one, or The current aftermarket ones are different to the originals??
1st December 2021, 10:24 AM
The 747
I can't answer the backwards compatibility, but have you checked where it is leaking from? Most likely it is the seal around the pump which would be a very easy fix.
I replaced my bottle a few years ago and the seals they come with are very poor and had to be replaced only a couple of months after installing it, from memory I made some seals out of rubber and sillasticed them in.
The Following 2 Users Say Thank You to Winnie For This Useful Post:
Cuppa (1st December 2021), mudski (1st December 2021)
1st December 2021, 12:19 PM
You're right @Winnie, I'll pull it out to check it first.
1st December 2021, 12:26 PM
Yeah Chris is on the money I reckon.
1st December 2021, 12:45 PM
If it is just a small crack it shouldn't be impossible to fix, afterall, we are not talking about hot/pressurized/vital fluid like cooling fluid. Any of those two-compound glue/resin should do the trick. Something I noticed though is that none of the picture shows the rear window pump. I suppose you searched specifically for an UTE?
1st December 2021, 02:51 PM
BrazilianY60
Yep you are correct.
1st December 2021, 06:33 PM
Winnie
Yep, I think you are spot on. Have removed the washer tank - bit of an effort due all the 'stuff' I have in the way, but I got there. Filled tank & watched.Sure enough the leak was coming from the seal area. But from around the outside of the seal, or from the inside where the pump fits? I suspect the outside & have now refitted the seal using the only 'goo' I have to hand - Roof & gutter silicone sealant. Did you put sealant both inside and outside of the seal?
1st December 2021, 07:05 PM
G'day mate,I had the same problem.
I bought a pair of new Chinese pumps with seals from ebay,only cost me about $20.
I'm still using the factory pumps with the new seals,fixed the problem and that was 3 years ago
7th December 2021, 08:07 AM
And back to the leaking windscreen washer bottle saga. <sigh>
Several attempts to seal the seal have failed. Primarily it seems because the rubber seal itself was not leaking. Tested this by finding something the right size to block the hole. No leak. Refit the pump -> leak. Grrr.
Patrolapart's web page says "A common thought is that the washer pump rubbers are leaking, however more often than not, it is the pump itself leaking through it's internal seals".
So hopefully a replacement pump will get me sorted. Patrolapart have two options, genuine & aftermarket, to suit my car.
