Results 1 to 10 of 10
Thread: '09 Brake Bleeding
    Advanced Mcflurry's Avatar
    Dec 2018
    '09 Brake Bleeding
    Hey all,
    Was planning on doing my brake fluid this afternoon however unsure whether there is a load adjustment valve or something else of this sort on a 2009 GU? Couldn't see anything that looked likely, but wanted to double check.
    2009 GU
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Yep - it's above the rear diff and most people (and mechanics) make the mistake of not bleeding it. It tends to collect moisture and gunk when not bled and then fail causing all sorts of brake issues. There are a number of threads here about the LPV.
    465 Post(s)
    you will have a bias valve in the rear. tucked up high above the diff centre.
    Dec 2018
    Thanks gents, does the bias valve get bled first and just the same as any other nipple?
    2009 GU
    465 Post(s)
    Quote Originally Posted by Mcflurry View Post
    Do the rear wheels first then bias valve, then the fronts.
    Mcflurry (20th September 2021)
    Dec 2018
    Legend thanks mate
    Sent from my Pixel 2 XL using Tapatalk
    2009 GU
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I think the manual says do the LSV first (I believe later GUs don't have one) then left rear, right rear then front. Disconnect battery if you have ABS.
    The LSV, if it's there, is the furthest point from the master cylinder.
    John
  10. The Following User Says Thank You to jff45 For This Useful Post:
    geoffayres (21st September 2021)
  11. #8
    465 Post(s)
    Yes you are right John. Valve first. The left and right rear. and I did not know the later models didn't have them. thats strange...
  12. #9
    Morayfield, QLD
    I think the later GUs had the ABS/VDC so the load sensing valve became unnecessary.
    John
  13. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (21st September 2021)
  14. #10
    Jul 2010
    Thurgoona
    7 Post(s)
    Mine has ABS and also the valve. The bleed nipple on the valve is not easy to get to if you don't have a hoist - but not impossible. When you bleed it look at the colour of the fluid that comes out. Usually if the valve has never been bled (a common issue) the fuid will be a dark colour.
