Results 1 to 9 of 9
Thread: Can someone please tell me what this is?!
    Advanced Mcflurry's Avatar
    Dec 2018
    Hey all,
    I've been starring at these slots for years with no clue what they are. Could someone please enlighten me? I want to mount a bluetooth speaker in here!
    Brad
    2009 GU
    176 Post(s)
    My UHF hand piece is mounted there.
    I took off the large square blank and mounted it to that.
    Apr 2021
    Brazil
    3 Post(s)
    The slots seems to be for the A/C temperature sensor.
  4. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    MudRunnerTD (31st August 2021)
    Dec 2018
    Thanks for the replies guys. I don't seem to have a temp sensor there Bazilian, maybe on TI models? Turns out it's a great spot for a microphone from my new stereo!
    2009 GU
    Patrol Guru paulyg's Avatar
    Ballarat
    On my TI, with climate control aircon, there is a tube there which must be the temp sensor that BrazillionY60 mentioned.
    At first glance Id say its a hole,
    but that's only a quick glance
    Is it a window defroster?
  8. #7
    Dec 2019
    Western Sydney, NSW.
    As stated above, I had seen in the Workshop Manual, that it's the vent where a sample tube is attached for the A/C Temperature Sensor takes it's samples from
    Grant
    Penrith Region
    Sydney NSW.
  9. #8
    176 Post(s)
    As I mentioned earlier.
    On my ST, there was nothing behind that tiny slotted section. I turned it into this ...
    Expert Mickhead's Avatar
    Oct 2019
    Every time you drive, you put a dollar coin into each slot. When later on your head gasket, fuel pump, clutch, cracked piston, glow plugs, alternator, cracked head, cooling system, death wobbles, or anything else needs attention, you have a reserve of cash. 😂😂😂
  11. The Following 2 Users Say Thank You to Mickhead For This Useful Post:
    Cremulator (6th September 2021), Rossco (6th September 2021)
