20th July 2021, 07:00 PM
Stropp
Thanks rossco I hope that’s what it is, I may just leave it for now and hopefully get up for you guys to have a listen and see, the original owner said it maybe the problem too and it was tuned in a warmer climate!
Yeah I was in the hope to get mine perfect but think it is 12mm thing, having seen many other 12mm TDs in the cold they all vary somewhat but overall tend to be be a bit rough on cold starts. . Mine even is a little unpredictable sometimes cold start is fine other times pops & smokes a fair bit but then all good. . At the end of the day is mechanical injection with more fuel and no boost on idle / startup so when frosty can't burn all fuel efficiently. Could do compression test for peace of mind and check glow plugs but certainly wouldn't worry about pulling the motor . .
20th July 2021 07:00 PM
20th July 2021, 07:15 PM
Smart like tractor
Dont pull the motor. Drop the oil and cut the filter open and look for shine bits first. Do a compression test and have the rocker cover off whilst you turn it over and inspect the valve train for anything out of the ordinary
96 GQ coil/Cab
08 G6eT
![](image.php?s=3d3a897d037eeed723b705ab588ceb96&u=1281&type=sigpic&dateline=1483248064)
The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
Rossco (20th July 2021), Stropp (20th July 2021)
20th July 2021, 08:13 PM
Ben-e-boy
Sounds like a plan mate.
24th July 2021, 05:35 PM
Still waiting on matt to get back to me about what h3 found when he cut the filters open
26th July 2021, 10:10 AM
I think you will find it is the set up inside the injection pup .
have seen a few here that are rowdy on cold start .when its cold . to far advanced ... mostly with the 12mm Mod .
Dave At cooma diesel knows a bit about it ..
The Following User Says Thank You to Tip12345 For This Useful Post:
3rd August 2021, 03:41 PM
Ok so no metal in the filters so just gave it a service and see how it goes but I will be putting some mineral oil in the diesel to see if it quietens down a bit. Thanks for the tip BEN-E
The Following User Says Thank You to Stropp For This Useful Post:
3rd August 2021, 09:39 PM
#17
Yeah the old two stroke oil in the fuel helped with mine.
Rossco (4th August 2021), Stropp (3rd August 2021)
3rd August 2021, 10:02 PM
#18
mudski
Yes and my old one, be interested to see how much it quietens down on the 12mm
6th August 2021, 05:44 PM
#19
Smart like tractor
I cant believe that particular company's fault finding method is 1. check the injectors, 2, pull the motor. 3, (im guessing) give the customer a hefty bill.
That genuinely pisses me off reading that. What if it was an out of spec tappet, a 20k km check as part of periodic inspection/maintenance? An easy fix too!
You shouldn't have to come to a forum (after discussing with a professional) and leave with some basic fault finding advice from a knuckledragger who plays with electricity after the pro has done basically nothing and is all out of ideas.
96 GQ coil/Cab
08 G6eT
The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
Avo (7th August 2021), Hodge (6th August 2021), Stropp (6th August 2021)
6th August 2021, 06:59 PM
#20
Ben-e-boy
knuckledragger who plays with electricity .
What's wrong with knuckledraggers who play with electricity ![](https://s3.amazonaws.com/tapatalk-emoji/emoji12.png)
![](https://s3.amazonaws.com/tapatalk-emoji/emoji1787.png)
The Following 2 Users Say Thank You to Hodge For This Useful Post:
Avo (7th August 2021), Rossco (6th August 2021)
