Results 11 to 20 of 34
Thread: New winch needed or not??
    81 Post(s)
    I did read that the Runvas have a braking mech in the gearbox, not inside the spool.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    jay see (13th July 2021)
  3. #12
    Runva all the way.
    Stay away from Carbon is all I will recommend.
    https://www.productreview.com.au/lis...synthetic-rope
    Check out the last review and photos.
  4. The Following User Says Thank You to jay see For This Useful Post:
    Hodge (14th July 2021)
  5. #13
    Yeah, they call it a ratchet system. It's to prevent heat from a traditional drum brake.
  6. The Following User Says Thank You to jay see For This Useful Post:
    mudnut (14th July 2021)
  7. #14
    176 Post(s)
    If I showed you and told you my recent experience with them. You wouldn't believe me.
    I won't drag names through mud on here.
    But like I said , I recommend you steer clear.
    Check your PM .
    81 Post(s)
    Do tell, Hodge.
  9. The Following User Says Thank You to mudnut For This Useful Post:
    Rossco (14th July 2021)
  10. #16
    Ok.
    I've disconnected everything going to the solenoid, the neg and the red terminal from the winch do its free on any power. Then I connected a battery, neg to neg on winch and positive to red on winch. Got a little spark on contact, but no movement at all. Am I doing this correct??
    While all connected to the external battery it goes from 12.2v - 6.0v. is there not enough juice in the battery to get it moving or is the winch dead??
  11. #17
    I think is safe to say that it's dead, If I have done this right.
    Tried it again, but this time connected to the car battery and engine running, no difference.
    Now if I get a bare winch I run all my existing cables, solenoid and rope everything should fit just a remove and replace yeah....
    EDIT....
    And I also connected a cable (the brown one in the pic) from the red terminal to the yellow one with no difference.
  12. #18
    197 Post(s)
  13. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    jay see (17th July 2021), mudnut (17th July 2021)
  14. #19
    Cheers pb
    Looks like I had the power on the wrong terminal.
    And of course before I put the bar back on I gave it a go and it worked, not everytime I hit the switch, but it did work and then when it's all put back together, it doesn't work.
    I pretty sure that the motor works, it's just that it doesn't work everytime the switch is pushed
  15. The Following User Says Thank You to jay see For This Useful Post:
    PeeBee (17th July 2021)
  16. #20
    81 Post(s)
    Is it a wireless controller, or the cable unit? Maybe a wire is loose inside the control box.
  17. The Following User Says Thank You to mudnut For This Useful Post:
