Results 1 to 10 of 16
Thread: Tyre flat spots
    176 Post(s)
    Tyre flat spots
    Has anyone experienced tyre flat spots, sometimes after only a day or two of being parked?
    The Patrol sits parked in one spot for a whole week, every 6 weeks. And for a while I've experience that flat spot effect after the initial drive and/or the tyre warms up.
    But last several months, I've began noticing it sometimes after it's parked overnight... Driving off, I notice that small "thump" every wheel rotation... I can't pin point which tyre it is.
    I've never locked the wheels up, so i doubt it's flattened out in a spot from braking. Apart from possibly pressures being a factor, what can contribute to this? Age of tyre, getting softer, harder?
    6 year old Mickey Thompson ATZ P3's. 33". Done 60,000-ish...
    81 Post(s)
    Yep, Hodge. But my Old Trol sits for many days at a time. It usually disappears after a minute or two up to about 60. After that the death wobble took over. Hopefully with the new steering damper, it might not be as noticeable.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    Hodge (14th June 2021)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    It could be a mixture of old harder rubber with maybe not enough pressure for the weight. You could try increasing to more than normal pressure before parking and air down when you use the car again.
    Personally, I don’t keep tyres past 5 years.
    John
  5. The Following User Says Thank You to jff45 For This Useful Post:
    176 Post(s)
    Thanks for the responses.
    I'll give more PSI a go see what happens ...
    I run 32-34 around town. Might boost it to 40 and see how I go.
    I have a new set on order . Waiting for arrival with no ETA at the moment ...
    But there is definitely a flat spot developing even after parking it overnight.
    Could be the pressures . Not sure.
    477 Post(s)
    Far from a tyre expert me Hodgey Mate (disclaimer:-) but those pressures do sound a whisker low Brother.
    BFG & Nitto’s of late in the 33” range too I’ve been running at around 35psi fronts and 40psi rears especially on the load utes.
    GU’s are exceptionally heavy as you’ve got and we all know it’s nearly impossible to keep a great wagon under GVM glovebox sticker recommendations
    A simple idea could be?
    Jack your beast up, paint some water based white on the treads, allow to dry, then do some quick test runs to see if the outer edges wear first (under inflated) and or the inner tread wears (over inflated) maybe?
  8. The Following 2 Users Say Thank You to MB For This Useful Post:
    Hodge (14th June 2021), jay see (26th June 2021)
  9. #6
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    mine sits for 2wks at a time, the flat spots are definitely noticeable during my first few laps around the block...
    2008 CRD Auto Wagon
  10. The Following User Says Thank You to pollenface For This Useful Post:
  11. #7
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    You could always try something like these......
    Tyre Savers
  12. The Following 2 Users Say Thank You to 04OFF For This Useful Post:
    Hodge (25th June 2021), MB (26th June 2021)
  13. #8
    176 Post(s)
    Since I posted this up, I've been messing with the pressures. And they DO make a huge difference. It's obvious the lower the pressures (softer tyre) the easier/quicker the footprint/flatspot will occur.
    I've been running higher pressures than usual on the road too, and the wobbles I sometimes get at 80-90km/h have moved up to near 100kmh-ish, or almost gone.
    Also, I "think" the ageing of the tyre makes it more prone to a flatspot, even overnight like mine for example. But I do believe it is only "one" tyre thats a defect not all. So, who knows...
    Anyway, a new set coming up soon.
  14. The Following User Says Thank You to Hodge For This Useful Post:
    MB (26th June 2021)
  15. #9
    477 Post(s)
    Just re-reading your quandary Hodgey Mate
    Seems strange that I foolishly left my beloved bigger KM2’s on the Shed Queen GU Chev for many years in the same spot, a quick squirt up the road every 3-6 months to reminisce
    Chucked those old faithful bigger KM2’s on the GQ ute after guard work and ran perfect round instantly.
    The only other Bloke I know of that complained about severe regular (first 50km iron out) flat spots was a Mickey owner whom also left his for months at a time?
    As I’ve said previously (uneducated) I feel tyres are getting softer and softer memory lacking too maybe?
  16. The Following User Says Thank You to MB For This Useful Post:
    Hodge (26th June 2021)
  17. #10
    Yeah weird... Our forklift at work has just been changed from solid rubber to new pneumatic tyres for aided traction in our gravelled yard. Doesn't take long to create man-boob jiggling flat spots on the tyres.
    Dunno how that is relevant but there you have it......
    The nitto mud tyres I have on the GQ sit for months at a time at 40PSI and create no noticeable flat spots.
  18. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Hodge (27th June 2021), MB (26th June 2021)
