Page 1003 of 1056 FirstFirst ... 35039039539931001100210031004100510131053 ... LastLast
Results 10,021 to 10,030 of 10551
  1. #10021
    22 Post(s)
    I put my old rear Superflex sway bar in the soft roader. Having the factory sub tank made the drivers side bracket a monumental pain in the arse to install
    96 GQ coil/Cab
    08 G6eT
  2. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    MB (27th May 2021)
    475 Post(s)
    @MudRunnerTD Mate, your Beast needs these too Brother
    I’m assuming Ben Suspension Legend had this rear Superior installed up his ‘Champion Link TK’ video climb?
    MudRunnerTD (27th May 2021)
  6. #10023
    330 Post(s)
    Sway Bars are Overrated......
    Nah i have that sway bar on the front of the GU actually. Yeah i would like to refit some sway bars... One day.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (28th May 2021)
  8. #10024
    330 Post(s)
    I made a little frame up to house my compressor and tank. I just need to sort some conduit and an anderson plug out for the supply cables and it'll be good enough for a bit
    Once I get my new canopy, that whole setup will end up on runners and built into a bigger frame with outlets between the tray and cab
    Attachment 83635
    Attachment 83636
    Nice one Bene, did i miss a post? have you bought a new Patrol mate? a Build Thread is required bud!
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Hodge (28th May 2021)
  10. #10025
    22 Post(s)
    Yes I bought a GU. Its only a soft roader. Legal lift, mufflers, sway bars. It's for real legal and road worthy and will pretty much remain fairly close to that. I need to build it a bit before it gets a build thread.
    This post
    http://www.nissanpatrol.com.au/forum...930#post818930
    96 GQ coil/Cab
    08 G6eT
  11. The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
    BrazilianY60 (19th June 2021), MB (29th May 2021), MudRunnerTD (28th May 2021)
  12. #10026
    475 Post(s)
    Time for some legal highway work runs soon so bought Golden Oldie some fresh boots:
    BFG All Terrain KO2’s 33 x 12.5 R15 (previous models, soon to be discontinued like my beloved KM2 Mud series already gone)
    Some fresh new Dynamic tough and safe steelies too for only $95 a piece so spoilt the old truck with some fresh new matching black nuts as well
  13. The Following 6 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (19th June 2021), Cremulator (4th June 2021), Hodge (3rd June 2021), jay see (4th June 2021), Rossco (3rd June 2021), rusty_nail (5th June 2021)
  14. #10027
    Ballarat, Vic
    174 Post(s)
    Finished packing & prepping our Patrol (& Tvan) for our forthcoming trip up the Cape. Leaving Saturday via Chillagoe. Excitement (mixed with a little apprehension) is building. Will be on the Old Coach Road on Sunday.
  15. The Following 4 Users Say Thank You to Cuppa For This Useful Post:
    jay see (4th June 2021), MB (3rd June 2021), mudnut (3rd June 2021), Rossco (3rd June 2021)
  16. #10028
    80 Post(s)
    Chasing a slight wobble at 70-80kph. Nipped up the passenger side wheel bearing, and replaced the steering damper. The new one does not feel as solid as the old one, but it seemed to get better after a few pumps. Hopefully it will bed in with use.
  17. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    jay see (4th June 2021), MB (4th June 2021), mudski (4th June 2021)
  18. #10029
    80 Post(s)
    Took it for a test run and its worse. I'll give it a week and if it doesn't settle down I'll take the bastard back. I hate having to do a job 3 times.
  19. The Following User Says Thank You to mudnut For This Useful Post:
    MB (4th June 2021)
  20. #10030
    475 Post(s)
    Wanker style replying to ones own post
    FWIW: The first time I’ve ever owned 12.5” wide Road/All Terrain type tyres, always them widths have been M/T chunkier piercing off-road variants.
    Wet local windy highway early this morning (shithouse road maintenance with decent puddles galore) managed to slightly step out the front and arse end ‘Aquaplaning’
    Lucky I drive like a daily Grandpa in the massive 70rwkw TD42 and hoping they’ll prove their worth on some drier highways and bull dust/sand flat width one day soon
  21. The Following 3 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (19th June 2021), Mickhead (5th June 2021), PeeBee (5th June 2021)
