WOW, that is super bad luck - is it a common failure point on that engine?
MB (26th April 2021)
Not sure if its common, but they call them grenades and it lived up to its reputation ! Weird thing is both rear valves in the front cylinder have been bent, one inlet and one exhaust. The front ones seem fine, not sure how this is possible!
Oops wrong pic look at the dents in the buckets ! C98A6F87-2D8D-4F5B-8759-FEC0DBB969FF.jpeg
MB (26th April 2021), rusty_nail (25th April 2021)
I'm not really a fan of the Redarc boost and pyro gauge. The dials are too small So I dragged out my old VDO stuff and mounted around the gauge cluster.
Removing the Redarc means I have also lost the coolant temp, I think I'll order the Redarc oil pressure gauge and utilise the coolant temp sensor too. That'll cover most of whats going on
96 GQ coil/Cab
08 G6eT
I love my McNally Boost and EGT gauge.
so how much boost are you running ?
mudski (27th April 2021)
Fresh LSD oil and swapped the alternator just before.
Beer o'clock .
