1st May 2021, 09:53 PM
One job becomes two. three .......
Hi All
I can't be the only one.
Jobs seem to multiply.
I changed an engine mount on my TD42T GU on the passengers side. The other looked in very good condition.
When I jacked the motor up I placed a large piece of wood between the jack and sump.
As I jacked it up I kept an eye on the sump and only went just enough to get the mount out.
When I started the car it sounded like someone doing a fast bang on a steel drum.
The sump must have deformed a bit. Not enough to see.
Oil drained, sump off and two little tell tail marks inside.
I went over it with a straight edge and took measurements then did a bit of panel beating.
The area where it was hitting went from 34mm to 42mm from the sealing face.
Put it all back together again with new oil.
No more banging.
2.5 hrs gone on a job I shouldn't of had to do. GRRR
If you don't cause another job you notice another job that needs doing.
I repaired a lose drivers mirror. The 3 screws that hold the head to the base were seized and unable to be tightened.
CRC and vice grips sorted out 2 and the other needed the head drilled off. Once separated I was able to get vice grips on the shank off the screw.
New stainless bolts and she's all fixed. Putting the mirror back on the door I noticed the bailey channel rubber was falling apart.
One job becomes Two.
Cheers Shane
The Following 3 Users Say Thank You to Shalee For This Useful Post:
BrazilianY60 (4th May 2021), MB (4th May 2021), PeeBee (2nd May 2021)
1st May 2021 09:53 PM
2nd May 2021, 06:45 AM
The more you do the more you find, the more you do the more you find - on it goes, not new ground unfortunately. Good thing though is the problems get resolved before they get bigger
Cremulator (2nd May 2021)
2nd May 2021, 06:50 PM
Buying an old car you expect to do some work to get it bush ready.
I'm slowly working through the list.
One day I'll get there and it will just be maintenance from then on.
The Following User Says Thank You to Shalee For This Useful Post:
6th May 2021, 12:38 AM
I do it all the time, and kick myself for it.
I call it a learning experience.
