Page 498 of 568 FirstFirst ... 496497498499500 ... LastLast
Results 4,971 to 4,980 of 5677
  1. #4971
    176 Post(s)
    100%
    I still have not found another offroad map anywhere that comes close to being on the same level as the Rooftops.
    I suppose it takes a special kind of person!
    Don't know how it compares, but Hema just released an update for their 4wd app which includes a number of new maps, including 8 maps covering the Vic High Country with most, if not all tracks named. Pic is a screenshot of part of one map, from my phone.
  2. #4972
    For comparison, here is an example of the detail of Rooftop maps.
  3. #4973
    195 Post(s)
    I think the thing with rooftops is all the little bits of info and the reliability of it too. There's so much stuff I've found in the bush that would have never if known about, huts, waterfalls mines etc, plus info on track conditions is pretty bang on. .
  4. #4974
    197 Post(s)
    I recall reading an article in a 4wd magazine many years ago, and it showed an amazing stretch of water with a huge deep fishing hole. I tried to find the location on the maps based on the description in the article. I ended up making contact with the old guy who does the rooftop maps and he was really helpful. I told him the story, gave him the description and approx location - somewhere close to Bindaree Hut from memory. I then rang him back next day and he had gone thru his trek notes and photos and confirmed 100% the spot was not near the hut as noted. He physically walked every track himself in those day, so he knows the content back to front. In the end I never found the fishing spot - may have been deliberately disguised in the article to protect its exclusivity.
  5. #4975
    Yeah he is an amazing cartographer and a brilliant athlete, but he is a bad man.
    https://www.theage.com.au/national/t...13-ge0oo4.html
  6. The Following 4 Users Say Thank You to Winnie For This Useful Post:
    MudRunnerTD (22nd April 2021), PeeBee (9th April 2021), Rossco (9th April 2021), Stropp (11th April 2021)
  7. #4976
    176 Post(s)
    Yep fair enough , the Rooftop maps do definitely look better. However the new Hema map set for the high country might come a reasonable second best. At the scale in Winnies screen shot Rooftop has more info & is clearer than Hema. With Hema you would need to switch between two zoom levels to see the contours & all the track names. Less 'points of interest on the Hema too.
  8. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
  9. #4977
    195 Post(s)
    There's alot of work involved in putting the paper maps onto something and georeferencing and only really worth it if you spend a heap of time in the high country, but if you do they're bloody awesome ! . . Massive thanks to Drewboys wicked thread on the forum don't think I would have ever worked it out without lol . .
  10. #4978
    Expert Truckus's Avatar
    Feb 2021
    Central Coast NSW
    Strongly recommend you get a fluid damper instead of the factory 3 part rubber balancer. They are a big improvement and helps with reducing risk of crank failure which is an issue with these motors. Is that a new crate motor? From BD?
    Yep, sure is. Transferred funds across this morning.
    2005 Y61 GU rebuilt 2020. 6.5 L turbo inter-cooled Diesel, SupENG Superflex 4 Inch Lift Kit 2,0 Remote res Fox shocks, offset trunions, 315/75/16 Maxxis Razr, 16 x 8 steel rims, SupENG drop box, Stedi Spots & bars, 12000 lbs winch,rear locking bars with duel tire carriers, 4” XtremeENG S/S snorkel, rock sliders, SME UHF, ARB Hard mount Air compressor, ARB fwd & rear air lockers,Rhino roof racks, Duel battery set up, 12 V dist swbd ,
  11. #4979
    Being that the new Musso is new in Australia, aftermarket options are very limited. Also, mostly they are crap. I have resorted to looking for universal solutions. Some that know me know I do alot of timber work which means transporting long lengths. This is the start of my working out a longer vehicle rack. I'll be adding a tray to the frame, but not until I find roof racks that aren't clamp mount type. At this time the only type in Australia that are available are clamp mount and I think that design is absolutely puss. Anyway, happy with the frame, the build quality is great, it's solid as a rock and will suit my need perfectly. Oh and I reckon it was a good price. $699 including shipping.
  12. The Following 5 Users Say Thank You to rusty_nail For This Useful Post:
    Cremulator (10th April 2021), jay see (9th April 2021), MB (10th April 2021), MudRunnerTD (22nd April 2021), Stropp (11th April 2021)
  13. #4980
    Depending on your roof style clamps might be the only option. Some models do have the rails bolt onto them that run front to back but if they arent there fron factory then it won't leave any other option. Some rack manufacturers will instruct you to remove the roof liner and drill holes but this isn't great either.
  14. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    MB (17th April 2021), rusty_nail (9th April 2021), Stropp (11th April 2021)
