Results 1 to 10 of 18
Thread: GU windscreen washers !
    May 2016
    8 Post(s)
    Hi all is it a feature or a fault ?
    The washers on the bonnet ! the drivers side work well but the passengers side are crap. I have cleaned the jets out and soaked in Clr etc but can get much on the passengers side . is there some sort of restrictor missing .
    81 Post(s)
    Probably just a lot of crud built up that keeps blocking it up. You might have to clean the lines all the way back to the bottle.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    MB (16th December 2020)
    469 Post(s)
    There’s a plastic T piece on the underside of the hood. This might be blocked or split. But it would leak if it was split. More than likely a blockage between the T and the nozzle. More than likely the nozzle is rooted.
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    Keep a sewing pin in the ashtray and poke them when the clog up. They get calcified.
    I also run metho in the water, it smells less toxic then windscreen washer stuff, does a good job and stops the algae/bacteria from brewing.
    I actually haven't seen metho on the shelves since covid.
    Whatever you do, don't fill the washer bottle with apple cider, I did once and a month later I regretted it.
    2008 CRD Auto Wagon
  7. The Following User Says Thank You to pollenface For This Useful Post:
    MB (13th December 2020)
  8. #5
    Sep 2020
    I was experiencing the same thing ended up removing the washer motor cleanjng as best I could and replaced the lines and tpiece and somewhere along the way fixed them.
    Using a bit of diluted CLR and pumping through the washer motor helped clean mine up a considerable amount. Hope that helps 👌
  9. The Following User Says Thank You to Moistyz For This Useful Post:
  10. #6
    469 Post(s)
    Quote Originally Posted by pollenface View Post
    Say what?! Why?
  11. #7
    Nov 2019
    Perth
    5 Post(s)
    Say what?! Why?
    It smelled horrible and didn't really assist in washing the windscreen. Live and learn I suppose...
    2008 CRD Auto Wagon
  12. The Following User Says Thank You to pollenface For This Useful Post:
  13. #8
    469 Post(s)
    Im just trying to comprehend why one would even think of using apple cider vinegar in the first place.
  14. #9
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Ran out of Bundy?
  15. The Following User Says Thank You to Brissieboy For This Useful Post:
  16. #10
    469 Post(s)
    Quote Originally Posted by Brissieboy View Post
    Ran out of Bundy?
