9th August 2020, 06:19 PM
#431
jay see (9th August 2020)
9th August 2020 06:19 PM
9th August 2020, 08:59 PM
#432
Moderator
Mickhead
Looks great but it doesn't do Mig Bugger it. If it did I might grab it myself.
Check out my Toy -->
Rogue Dung Beetle
9th August 2020, 10:27 PM
#433
TPC
Why wouldn't you use it?
It’s a limited numbered collectors item. Once my room down stairs is done I’ll get another dart board to use.
9th August 2020, 10:34 PM
#434
mudski
Or you could give it to me and I'll use it. Limited number collectors. 🥱
9th August 2020, 11:17 PM
#435
mudski
Would be worth more with some holes in it.
The Following User Says Thank You to TPC For This Useful Post:
MudRunnerTD (10th August 2020)
10th August 2020, 10:04 PM
#436
jay see
$550 and its yours.
TPC
Definitely not.
11th August 2020, 08:15 AM
#437
jay see
Wanting to buy a welder..
Something just for the odd job at home.
What have people got and what do you recommend.
John I bought a Cigweld gas/gas less welder. Cost about $100 a year to rent a gas bottle. It’s cheaper these days to buy outright and just fill it when needed.
Mines not too notch but it has work well for anything I’ve used it for.
13th August 2020, 01:25 AM
#438
Mickhead
This looks good. It's a MIG Gas/Gasless and MMA/Stick electrode as well as DC TIG welder.
Bunnings have it for $500
mudski
I see yours is a130 amp. Do you trip your power when using it. Talking to a few welders at work they all said go at least 170 amp.
13th August 2020, 08:11 AM
#439
jay see
Thats welders talking... I welded 3mm plate on the bull bar with this mig not even on the highest setting and it worked a treat. I'd have to look at the spec on the inside of the access panel on the welder but I think it does up to 5mm. And my house was built in the early 70's, original house wiring, and I have burnt the house down. The breakers didn't go off so its not overloading the system.
The welder was on special somewhere when I got it. It was cheap. But bloody handy. And being Cigweld, they are a good brand so it was a no brainer.
One day I will upgrade with a Tig, not sure if I would use this or not. The welder doesn't get used much at all. I've had the same gas bottle for four years. Lol.
13th August 2020, 03:52 PM
#440
mudski
I've got a tig and am always on the look out for a cheap/good mig. The tig is very handy but a bit tricky to get used too and significantly slower than a mig. I would save your pennies and stick with the mig unless you had a specific job for it or had the cash burning a hole in your pocket.
I'm not a welder though.. So take that with a grain of salt.
