Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: Old patrol roof rust repairs
    Sep 2019
    New Zealand
    4 Post(s)
    Quote Originally Posted by PureCaboose View Post
    It's amazing how much time we don't have when in quarantine (not that it changed anything for us, if anything we go out more. sigh)
    Yup... I work in IT so I am able to work from home pretty easily. Combine that with a senior management team that are bored senseless as a result of the lockdown, and it's very easy to get buried in more work than you would have otherwise.
  2. #22
    Sep 2019
    New Zealand
    4 Post(s)
    Some more progress...
    Finished welding in and grinding back a patch:
    Complete with some primer:
    Marked out some steel:
    Then chopped it up:
    I did three of these in total, then ran them through the bender and welded them end to end.
    The end result is too long to easily take a photo of, but it should be welded to the side of the frame rail in due course.
    Cleaned up the rear of the thing - removed what remained of the rear gutter and marked out the bit I need to cut out and patch:
    I ground off the rust in the good areas and gave them a shot of primer, but it was too dark to get a good photo.
    The next task is the back corner. A bit rusty...
    I'll have to fabricate and weld in a temporary support for the roof frame before I chop that lot out.
  3. The Following 2 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (18th May 2020), Sherro (16th May 2020)
  4. #23
    197 Post(s)
    You are amazing, brilliant work, top stuff
  5. #24
    Sep 2019
    New Zealand
    4 Post(s)
    Time to do something about the rear right corner of this thing...
    Welded in some temporary support struts:
    Removed the rusted bit of the existing support, removed the remains of the gutter and marked out the intended path of the body saw:
    Marked out the cut on the rear:
    A few moments with the body saw... no more rust, but some big holes to patch:
    Test fitted the gutter I fabricated earlier:
    Needs to be another 250mm longer, but looks like it'll work.
  6. The Following 6 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (18th May 2020), Cremulator (9th July 2020), mudnut (18th May 2020), MudRunnerTD (22nd February 2021), oxmann (9th July 2020), Rossco (17th May 2020)
  7. #25
    Advanced oxmann's Avatar
    Nov 2012
    Auck, NZ
    How is your project coming along ? would love to see some more updates.I have just started doing this to my "92 GQ patrol" not as bad as yours, but still needs doing....and your pics,ideas etc are excellent.I see you are in NZ as I am,where abouts ?? Anyway thanks for your project updates,would love to see some more....cheers
  8. #26
    Sep 2019
    New Zealand
    4 Post(s)
    Some overdue progress...
    Unfortunately life and Auckland weather have been getting in the way as of late, but I have managed to get a bit more done:
    Time to do something about this oddly shaped hole where the A-Pillar connects to the roof frame...
    Cut up some patch plates and give them a shot of weld-thru:
    Do a bunch of fiddly welding to rebuild the edge piece:
    Weld in the first part of the patch (had to call it a day at this point so I just fired some primer over it):
    Picking up where I left off, grind back the primer etc. and get ready for more patching:
    In with the next patch. This area has a join between panels, so I replicated that with my repair (overlap & plug welds):
    Weld everything up:
    Apply the finger sander, angle grinder and die grinder:
    Hide all that with some primer:
    That's all the rust in the driver's door are repaired, on to the rear end.
    Tack in the patches:
    Some more welding...
    Add some primer:
    Just need to finish off the back right corner, then the drivers side frame repairs will be complete.
  9. The Following 6 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (25th July 2020), Cremulator (26th July 2020), mudnut (25th July 2020), Plasnart (25th July 2020), Rossco (25th July 2020), Sherro (25th July 2020)
  10. #27
    Sep 2019
    New Zealand
    4 Post(s)
    More cutting and welding...
    Got this weirdly shaped rusty area on the right rear corner to sort out:
    Made up a patch using a paper template:
    Tacked in place:
    Welded in:
    Hit with the grindy tools:
    Quick squirt of weld-thr:
    Now for this one... As it was originally where two panels overlap and join, this was a little more complicated.
    Weld in the first patch:
    Grind it flush:
    Stick the second patch over the top:
    Weld it in:
    Grind it back:
    Apply paint:
    With this bit done, I can now say that the driver's side roof frame is rust free!
    Next is to fabricate and weld on a new gutter, then do something about the roof support framework that is currently hanging mid-air.
  11. The Following 6 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (26th July 2020), Cremulator (26th July 2020), MB (6th August 2020), mudnut (26th July 2020), Plasnart (26th July 2020), Sherro (26th July 2020)
  12. #28
    Sep 2019
    New Zealand
    4 Post(s)
    Driver's side gutter time
    Managed to get the driver's side gutter completed and on the truck.
    Fabricate the last piece that fits at the front:
    Weld it on the bit I made earlier, grind it back and paint it:
    Spend quite a long time doing many, many plug welds:
    Almost there (welding up the front at this point)
    Gutter attached:
  13. The Following 8 Users Say Thank You to Nhoward For This Useful Post:
    0-TJ-0 (8th August 2020), BrazilianY60 (31st May 2021), Cremulator (6th August 2020), MB (6th August 2020), MudRunnerTD (22nd February 2021), Plasnart (6th August 2020), Rossco (21st August 2020), TimE (6th August 2020)
  14. #29
    Patrol Guru TimE's Avatar
    Canberra
    I admire your skills and patience
  15. #30
    81 Post(s)
    Looking good.
