23rd July 2020, 09:52 AM
threedogs
easy enough to change once the engine cover is removed.
Not sure on prices but a change ove IC fully tigged will
be approx 33% bigger
Yes it was easy. I paid $466 in Perth, I know there are some cheaper but they seem to be all sold out. I didn't want one of the +$1000 ones as we are planning to upgrade the car soon. I didn’t actually measure it but it appears to be the same size.
23rd July 2020 09:52 AM
23rd July 2020, 10:06 AM
Oddie1969
You need to remember its only a 3ltr it will only go sooo fast.
making it more efficient would be a better goal imo
Sounds like you got a great deal.
Oddie1969 (23rd July 2020)
23rd July 2020, 11:36 AM
You should definately fit a catch can, and not a cheapy from ebay because they don't have a baffle and are essentially useless. Also I don't think you really want a "breather" on a catch can other than a pressure relief valve. Normally being routed before the turbo the crankcase breather is under vacuum
I have the Flashlube Catchcan Pro, it was $229 from supersheap, it has 19mm fittings (you need to find some 16-19mm connectors) and a filter that should be replaced every 20,000kms, the genuine filter is about $90 although an aftermarket filter is about $35. I've caught about 400ml of oil in about 9000kms.
The Provent 200 is another popular one which I think has 25mm fittings. The HPD one doesn't perform well as it uses steel wool for the baffle which doesn't condense a lot of oil.
ARE is a good place to look for all things regarding intercoolers
https://www.are.com.au/Inter/topMountIntercoolers.htm
2008 CRD Auto Wagon
The Following User Says Thank You to pollenface For This Useful Post:
23rd July 2020, 09:17 PM
threedogs
I’m not needing it to go fast, I’m just trying to get as much power as I can to tow our new caravan.
The Following User Says Thank You to Oddie1969 For This Useful Post:
threedogs (24th July 2020)
23rd July 2020, 09:36 PM
pollenface
Looks like a catch can is the next thing on my shopping list.
I was looking at this one https://demonproparts.com.au/product...trol-zd30-3-0l, I don’t know if it’s any better but it looks like it has the 16mm fittings.
Thanks for the ARE link, there is some good information on there
24th July 2020, 12:52 AM
CC is a good investment. I run a Provent 200, few dollars but one of the proven designs. Try Western Filters.
Now that you have installed the new TIG welded cooler, guess you would have cleaned the air intake pipe to turbo and boost hoses, at least the one from turbo to the new cooler "hot side" _ by pulling some rag through??
The Following User Says Thank You to Bidja For This Useful Post:
Oddie1969 (24th July 2020)
24th July 2020, 10:22 AM
#17
Bidja
Ummm, no
24th July 2020, 10:40 AM
#18
Just good house keeping. Was there much oil residue in air intake duct (airbox to turbo) or boost hose from turbo to cooler. Give them a clean mate.
24th July 2020, 11:15 AM
#19
Bidja
I didn’t look at any of those ! I was more worried about making sure I didn’t break the engine while changing the intercooler, I will be checking all these things this morning, thanks.
26th July 2020, 02:22 PM
#20
Oddie1969
It has a stainless mesh filter so will not likely be as good at catching oil as the Provent or Flashlube CC.
Oddie1969 (27th July 2020)
