Results 11 to 20 of 26
Thread: ZD30 intercooler
    Advanced Oddie1969's Avatar
    Jun 2013
    Perth
    easy enough to change once the engine cover is removed.
    Not sure on prices but a change ove IC fully tigged will
    be approx 33% bigger
    Yes it was easy. I paid $466 in Perth, I know there are some cheaper but they seem to be all sold out. I didn't want one of the +$1000 ones as we are planning to upgrade the car soon. I didn’t actually measure it but it appears to be the same size.
  2. #12
    Quote Originally Posted by Oddie1969 View Post
    You need to remember its only a 3ltr it will only go sooo fast.
    making it more efficient would be a better goal imo
    Sounds like you got a great deal.
    Oddie1969 (23rd July 2020)
  4. #13
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    You should definately fit a catch can, and not a cheapy from ebay because they don't have a baffle and are essentially useless. Also I don't think you really want a "breather" on a catch can other than a pressure relief valve. Normally being routed before the turbo the crankcase breather is under vacuum
    I have the Flashlube Catchcan Pro, it was $229 from supersheap, it has 19mm fittings (you need to find some 16-19mm connectors) and a filter that should be replaced every 20,000kms, the genuine filter is about $90 although an aftermarket filter is about $35. I've caught about 400ml of oil in about 9000kms.
    The Provent 200 is another popular one which I think has 25mm fittings. The HPD one doesn't perform well as it uses steel wool for the baffle which doesn't condense a lot of oil.
    ARE is a good place to look for all things regarding intercoolers
    https://www.are.com.au/Inter/topMountIntercoolers.htm
    2008 CRD Auto Wagon
  5. The Following User Says Thank You to pollenface For This Useful Post:
  6. #14
    Jun 2013
    Perth
    I’m not needing it to go fast, I’m just trying to get as much power as I can to tow our new caravan.
  7. The Following User Says Thank You to Oddie1969 For This Useful Post:
    threedogs (24th July 2020)
  8. #15
    Jun 2013
    Perth
    Quote Originally Posted by pollenface View Post
    Looks like a catch can is the next thing on my shopping list.
    I was looking at this one https://demonproparts.com.au/product...trol-zd30-3-0l, I don’t know if it’s any better but it looks like it has the 16mm fittings.
    Thanks for the ARE link, there is some good information on there
  9. #16
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    CC is a good investment. I run a Provent 200, few dollars but one of the proven designs. Try Western Filters.
    Now that you have installed the new TIG welded cooler, guess you would have cleaned the air intake pipe to turbo and boost hoses, at least the one from turbo to the new cooler "hot side" _ by pulling some rag through??
  10. The Following User Says Thank You to Bidja For This Useful Post:
    Oddie1969 (24th July 2020)
  11. #17
    Jun 2013
    Perth
    Ummm, no
  12. #18
    Jul 2017
    40 Post(s)
    Just good house keeping. Was there much oil residue in air intake duct (airbox to turbo) or boost hose from turbo to cooler. Give them a clean mate.
  13. The Following User Says Thank You to Bidja For This Useful Post:
  14. #19
    Jun 2013
    Perth
    I didn’t look at any of those ! I was more worried about making sure I didn’t break the engine while changing the intercooler, I will be checking all these things this morning, thanks.
  15. The Following User Says Thank You to Oddie1969 For This Useful Post:
    Bidja (24th July 2020)
  16. #20
    Nov 2019
    Perth
    5 Post(s)
    It has a stainless mesh filter so will not likely be as good at catching oil as the Provent or Flashlube CC.
    2008 CRD Auto Wagon
  17. The Following User Says Thank You to pollenface For This Useful Post:
    Oddie1969 (27th July 2020)
