1st June 2020, 10:06 AM
Nissan / Airtec Snorkel head
Does anyone know if there is a different head that can fitted onto the Nissan / Airtec snorkels. They look terrible and don't seem large enough.
Alternatively, does anyone know if you can replace the Nissan / Airtec snorkel with a Safari? Do the holes match up???
Thanks.
1st June 2020 10:06 AM
1st June 2020, 02:19 PM
What size is the snorkel where the ram head sits on? I get the Yota with their 79's come into my work a bit wanting to change the Toyota bowl setup to a Donaldson ram head. So we just need the pipe size to work out what you need.
1st June 2020, 02:54 PM
mudski
That sounds great Mark. The problem with the Airtec is that body of the snorkel follows the A pillar and the bend is in the head. So if you try to put a different head on it, the inlet ends up staring up at the sky.
I measure the diameter of the part that the head slips over as being 87mm.
1st June 2020, 09:29 PM
Ok so we'll say its 89mm, 3 1/2 inch. Theres not a whole lot you can do here. The only option I see is get a 45 degree adaptor which is 89mm ID to slip over the snorkel, then its 89mm OD then you can fit a standard Donaldson snorkel. In the hope that 45 degrees is what you require to see the snorkel head straight.
1st June 2020, 09:50 PM
Patrol Guru
Mate had an adapter made up (for his Tojo) at the local exhaust shop a few years ago. Might be worth a try?
The Following User Says Thank You to TimE For This Useful Post:
2nd June 2020, 11:38 AM
I've stumbled onto a bloke who prints up snorkel adapters on a 3D printer. I'm working with him to see what we can come up with.
The Following 2 Users Say Thank You to 10G For This Useful Post:
mudski (2nd June 2020), Rossco (2nd June 2020)
2nd June 2020, 02:12 PM
You want to hope it will be strong enough.
2nd June 2020, 07:15 PM
#8
Travelling Podologist
On the same note
Has anyone successfully managed to fit a cyclonic pre cleaner onto one of these snorkels. If so how & what size (min/max airflow) cleaner? (for TD42i)
2nd June 2020, 08:21 PM
#9
He prints the adaptors out of ABS and does something with acetone to make them stronger.
#10
mudski
Cuppa
On the same note
G'day Cuppa. That's what this blokes adaptors are for, so you can fit a pre-cleaner. As an example:
https://www.ebay.com.au/itm/14361418...torefresh=true
