So everybody services their cars at your place now.
mudnut (25th May 2020), MudRunnerTD (24th May 2020), Rossco (24th May 2020)
Avo (24th May 2020), MudRunnerTD (24th May 2020), PeeBee (24th May 2020)
One of the companies we do work for had a massive operator error based breakdown which ended up damaging high speed servo motors and their encoder cables/plugs. All the cable are custom length which is specific for the motor and servo drive unit. None of which is "off the shelf and readily available".
Last resort was to join on old cables that had good plugs but were hacked off to less than 1m long.
14 hours and 176 solder joints later all servo motors run and know where they are and what they're doing. Im stoked about that
96 GQ coil/Cab
08 G6eT
Avo (24th May 2020), MB (24th May 2020), mudnut (25th May 2020), MudRunnerTD (24th May 2020), PeeBee (24th May 2020)
Just cleaning up outside and have this playing. The state of music.
https://youtu.be/Fakg7VpCLpA
@rusty_nail the first band is what I was listening to driving up to our weekend away
rusty_nail (24th May 2020)
I did notice that glitch the other day I was going to post it but I got sidetracked
96 GQ coil/Cab
08 G6eT
Installed a 5kw diesel heater in our caravan yesterday. Only took a morning to do and they are absolutely unreal! They seriously PUMP some heat out and are crazy efficient on both power and fuel.
10G (25th May 2020), Avo (25th May 2020), BigRAWesty (3rd June 2020), MB (24th May 2020), mudnut (25th May 2020), MudRunnerTD (24th May 2020), mudski (25th May 2020), PeeBee (24th May 2020), Rossco (24th May 2020)
Well done Chrisso, you’ll love it mate!
Just be sure to never restrict the Webasto’s flow at all, my current silly design (dodgey plumbing up top) finds that it cuts out after P3 setting. Much like a hairdryer they appear to need full unrestricted airflow and are tops then
10G (25th May 2020)
