Page 30 of 106 FirstFirst ... 2829303132 ... LastLast
Results 291 to 300 of 1051
  1. #291
    Came across this. Be better than my current one, even with the long ass cable that I made it's still a pita.
    https://www.4x4andcamping.com.au/pro...flator-charger
  2. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (2nd May 2020), MB TD42 (4th May 2020)
  3. #292
    Quote Originally Posted by dpetersen View Post
    What would you guys say would be the minimum impact rate/torque required for rotating wheels on the patrol?
    Please do keep in mind that most of our Patrol OEM torque specs are circa 130Nm ish for wheel nuts I believe (double check your manual/model variants) to be sure!
    No particular favour but I’ve just downgraded my onboard 1,000Nm beast Milwaukee 18v 1/2” (ring drive a must/never pin) to a 600Nm 18v 1/2” ring drive purely for usage weight with crook hands.
    For tool longevity it is best I believe to go 1/2” drive as O-TJ-O kindly suggested above and I’d personally suggest at a least 300Nm minimum for cracking (undoing) stubborn wheel nuts especially on trailers that may sit around for a while.
    NEVER rely on your rattle gun to torque up to OEM wheel specs properly again when refitting.
    A torque wrench is the only way to be fully sure for that last correct nip up after spinning the nuts back on quickly with your new coming gun of choice
  4. The Following 4 Users Say Thank You to MB For This Useful Post:
    0-TJ-0 (3rd May 2020), dpetersen (7th May 2020), PeeBee (2nd May 2020), Rossco (4th May 2020)
  5. #293
    I run all makita battery gear for work, love it, so many different tools in the makita battery range. Am looking at getting a battery rattle gun to make wheel rotating quicker and easier. There’s a few different options though. What would you guys say would be the minimum impact rate/torque required for rotating wheels on the patrol?
    Happy to call past yours one arvo mate, I'm working in the west ATM so most arvos go home though GB. mine develops 2000nm I believe, have always tried to nip up the nuts after tightening by hand but have never been able to turn much more. Fwiw yes it's Makita.
  6. The Following User Says Thank You to rusty_nail For This Useful Post:
  7. #294
    FWIW: I’ve sheared wheel studs off at 200Nm with my bare hands :-)
    Winnie (2nd May 2020)
  9. #295
    I've seen your hands mate, they are untamed machines...
  10. The Following User Says Thank You to rusty_nail For This Useful Post:
    MB (2nd May 2020)
  11. #296
    197 Post(s)
    I am hoping Rusty means 200 not 2000? Typo I suggest. My 240V 1/2" driver runs out at 600nm and that will shift just about anything I will come across.
    MB (2nd May 2020)
  13. #297
  14. #298
    Agreed mate, I’ve been able to deliberately shear up to M14 maybe M16 mild steel bolts at work with only 1,000Nm
  15. #299
    197 Post(s)
    Is there a 12V impact wrench with an adjustable torque setting with display? My Hitachi is 'on or off', so I use it to rattle up to nip torque then finish off with the torque wrench.
  16. #300
    I’m sure they’ve probably invented mate but unsure if I’d personally trust it.
    Do know your boss will kick your arse if you were to drop his calibrated torque wrench from a massive 20cm height impact let alone rattling built into a gun all day?
