Page 24 of 57 FirstFirst ... 14222324252634 ... LastLast
Results 231 to 240 of 562
  1. #231
    196 Post(s)
    Interchiller Stage 2 kit ordered today, 3 weeks leadtime at the moment.
    https://fiinterchillers.com/products/
    https://youtu.be/ydax3oIz9cA
  2. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    0-TJ-0 (17th February 2020), 10G (17th March 2020), MB (24th February 2020), mudnut (17th February 2020), MudRunnerTD (27th February 2020)
    196 Post(s)
    Progress over the last 2 days, but some more annoying issues
    1) Redarc low water alarm fitted
    2) Boost gauge installed - VDO direct pressure line - no boost on gauge under WOT.
    3) Aux fuel tank gauge refitted - no dash light power feed to gauge - was working before
    4) Made bracket for ARB diff lock compressor - mounted up well in different location to original. reconfigure the air inlet filter
    5) Made bracket for brake vac pump reservoir. Big reservoir with gauge
    6) Hooked up 2nd fuel flowmeter sensor circuit
    7) Tidied up difflock wiring loom, reconnected to compressor - no power to the switch
    8) mounted new triple gauge cluster with 2 x EGT gauges and Boost - no dash lights in gauges.
    9) no smoke testing today.
    Tomorrow - if I have the strength/mindset, look into the electrical issues above, however bigger prize is to shift the existing a/c condenser back towards the radiator so the stage 2 interchiller condenser will fit with the existing 12V fans - going to be a painful day I think.
  5. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    0-TJ-0 (24th February 2020), 10G (17th March 2020), MB (24th February 2020), mudnut (24th February 2020), MudRunnerTD (27th February 2020)
  6. #233
    196 Post(s)
    Finished for this roster break. Twisted and bent pressure hose was the culprit on the boost gauge, so 1 hr later, all fixed. Spaced out the electric fans to generate the pocket for the additional condenser. Grill still goes on with a bit of care, so happy days. Still can't find the a/c trigger wire, looks like I will have to try and trace it from the switch, or simply leave it to the a/c guys when they run the new hoses and charge it up.
  7. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    0-TJ-0 (25th February 2020), 10G (17th March 2020), MB (25th February 2020), MudRunnerTD (27th February 2020)
  8. #234
    196 Post(s)
    Few pics of this rosters results. Need to re-stick the pod down though - next roster break.
  9. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    0-TJ-0 (26th February 2020), 10G (17th March 2020), MB (16th March 2020), MudRunnerTD (27th February 2020), Rossco (27th February 2020)
  10. #235
    196 Post(s)
    OK, interchiller in my hot hands, looking to install this roster break. Plus a new replacement condenser to replace the 23 YO one, and also a power upgrade pulley for the s/c to compensate for the intercooler pressure drop
  11. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    10G (17th March 2020), MB (16th March 2020), poindexter (13th March 2020)
  12. #236
    196 Post(s)
    Progress. Should finish the installation tomorrow to the point I can hook up the water circuitDay 1 progress.JPG
  13. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    0-TJ-0 (15th March 2020), 10G (17th March 2020), MB (16th March 2020), Rossco (14th March 2020)
  14. #237
    196 Post(s)
    Another big day, but steady steady. Interchiller is now mounted in a bomb proof enclosure, high volume 12V fan mounted, needed a new bracket as expected, will start running the lines for gas and water tomorrow. Looking for a slightly smaller oil cooler, circa 150 w x 200 high to get the heat load off the two condensors ( existing is 250 sq.). I will retain the second tube heat exchanger as it works well
  15. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
  16. #238
    196 Post(s)
    Nightmare day, hate this car, glad to go back to work, just not happening, bee stings by the handful.
  17. The Following User Says Thank You to PeeBee For This Useful Post:
    MudRunnerTD (17th March 2020)
  18. #239
    465 Post(s)
    Need a hug mate?
  19. The Following User Says Thank You to mudski For This Useful Post:
    PeeBee (16th March 2020)
  20. #240
    196 Post(s)
    Better day today, water to air circuit plumbed up with pressure, flowmeter and temperature sensors - just need to power them up now. Lines insulated. Resolved the 'odd ball fitting' off the condenser - metric m20 x 1.5P, Patrol a Part assisted with the solution, great service. Next roster will see the a/c hooked up. Noticed the s/c pulley has been touching the bonnet, so luck would have it the higher boost pulley is in my hands, so will fit it tomorrow morning before shed clean up ritualinterchiller 1.JPG
    Interchiller 2.JPG[ATTACH=CONFIG]80678[/ATTACH)
    Have also insulated the pump housing
  21. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    0-TJ-0 (17th March 2020), Cremulator (17th March 2020), mudski (18th March 2020)
