31st January 2020, 06:09 PM
#12701
Patrol Guru
Plasnart
39 degrees isn't even remotely extreme heat. Bring in a Jap CEO to shake these clowns up and get them running FFS.
I agree! Surely out comes down to management?
Check out this info from Wikipedia;
Japanese railways are among the most punctual in the world. The average delay on the Tokaido Shinkansen in fiscal 2018 was 0.7 minutes. When trains are delayed for five minutes, the conductor makes an announcement apologizing for the delay and the railway company may provide a "delay certificate"
0.7 minutes average delay for the whole year!!
31st January 2020 06:09 PM
31st January 2020, 08:00 PM
#12702
The Following 2 Users Say Thank You to MB For This Useful Post:
PeeBee (31st January 2020), Plasnart (31st January 2020)
31st January 2020, 08:09 PM
#12703
@MudRunnerTD @MB
Just curious what were the initial symptoms of the failing pumps in Tassie ?? Noise ? Lack of cooling ?
31st January 2020, 08:13 PM
#12704
31st January 2020, 08:18 PM
#12705
Breadmaker Shaker
Cremulator
![](https://s3.amazonaws.com/tapatalk-emoji/emoji15.png)
Crazy efficient eh? I work all around Vic and Oz contract to contract and spend a lot of time on the travel. Live in Geelong and when I need to go in and out of Melbourne CBD or inner suburbs for a month or so each day I public transport it as the road system from the west is so overloaded I can't guarantee I'll get to where I'm going on time. Then you get a 39 degree day and the train system chucks a wobbly. Ridiculous. At least today's return train left on time but again trundled along at trotting pace. Wasn't so pissed seeing it actually took off on time although late on arrival.
![](image.php?s=57e0a8c019da9b7686bd628b81388fc2&u=115&type=sigpic&dateline=1651651487)
The Following 2 Users Say Thank You to Plasnart For This Useful Post:
Cremulator (31st January 2020), MB (31st January 2020)
31st January 2020, 08:31 PM
#12706
Makes me angy having to change trains for a different gauge down to Geelong too mate :-)
31st January 2020, 08:35 PM
#12707
Breadmaker Shaker
MB
Ga-huk ga-huk we's a long way out boy!
The Following User Says Thank You to Plasnart For This Useful Post:
31st January 2020, 09:47 PM
#12708
Hodge
MudRunnerTD @
MB
Times UP :-)
Both Top Blokes unfortunate seperate trucks rear pump seals pooped out I believe and relief holes forward of bearings dumped the green stuff :-(
The Following User Says Thank You to MB For This Useful Post:
MudRunnerTD (1st February 2020)
31st January 2020, 09:59 PM
#12709
The 747
I believe the only warning was a big puddle of green coolant underneath the car.
The Following User Says Thank You to Winnie For This Useful Post:
31st January 2020, 10:29 PM
#12710
Patrol Guru
Hodge
MudRunnerTD @
MB
Water leaking from the tell tale hole is about the only way mate. It's just the seal that go on them. Impeller might wear out on a really old one but unlikely.
The tell tale hole is in the neck of the pump sorry if behind the pulley. Hard to see when it's all in place.
Darrens was so bad it was a jet stream coming out and very visible. With mine I originally thought it was just a leaky gasket so pulled it off and could make it the water mark coming from the weep hole so world of only got worse and worse.
What's yours doing?
Sent from my Pixel 3 using Tapatalk
The Following User Says Thank You to matfew For This Useful Post:
Hodge (31st January 2020)
