Page 1271 of 1459 FirstFirst ... 12691270127112721273 ... LastLast
Results 12,701 to 12,710 of 14585
  1. #12701
    Jun 2018
    24 Post(s)
    39 degrees isn't even remotely extreme heat. Bring in a Jap CEO to shake these clowns up and get them running FFS.
    I agree! Surely out comes down to management?
    Check out this info from Wikipedia;
    Japanese railways are among the most punctual in the world. The average delay on the Tokaido Shinkansen in fiscal 2018 was 0.7 minutes. When trains are delayed for five minutes, the conductor makes an announcement apologizing for the delay and the railway company may provide a "delay certificate"
    0.7 minutes average delay for the whole year!!
  2. #12702
    477 Post(s)
    Best way to beat road traffic and travel on their bigger neighbours turf too @320kmph only achieved top end there so far.
    Unfortunately they do suppress disasters that did occur from under engineering in earlier days trying to keep up with Japanese Jones’s.
  3. The Following 2 Users Say Thank You to MB For This Useful Post:
    PeeBee (31st January 2020), Plasnart (31st January 2020)
  4. #12703
    176 Post(s)
    @MudRunnerTD @MB
    Just curious what were the initial symptoms of the failing pumps in Tassie ?? Noise ? Lack of cooling ?
    477 Post(s)
    Not ours sorry Hodgey Mate, unsure of others symptoms but we all got there in the end
  6. #12705
    109 Post(s)
    Crazy efficient eh? I work all around Vic and Oz contract to contract and spend a lot of time on the travel. Live in Geelong and when I need to go in and out of Melbourne CBD or inner suburbs for a month or so each day I public transport it as the road system from the west is so overloaded I can't guarantee I'll get to where I'm going on time. Then you get a 39 degree day and the train system chucks a wobbly. Ridiculous. At least today's return train left on time but again trundled along at trotting pace. Wasn't so pissed seeing it actually took off on time although late on arrival.
  7. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    Cremulator (31st January 2020), MB (31st January 2020)
  8. #12706
    477 Post(s)
    Makes me angy having to change trains for a different gauge down to Geelong too mate :-)
  9. #12707
    109 Post(s)
    Ga-huk ga-huk we's a long way out boy!
  10. The Following User Says Thank You to Plasnart For This Useful Post:
  11. #12708
    477 Post(s)
    @MudRunnerTD @MB
    Times UP :-)
    Both Top Blokes unfortunate seperate trucks rear pump seals pooped out I believe and relief holes forward of bearings dumped the green stuff :-(
  12. The Following User Says Thank You to MB For This Useful Post:
    MudRunnerTD (1st February 2020)
  13. #12709
    I believe the only warning was a big puddle of green coolant underneath the car.
  14. The Following User Says Thank You to Winnie For This Useful Post:
  15. #12710
    Patrol Guru matfew's Avatar
    Nov 2012
    @MudRunnerTD @MB
    Water leaking from the tell tale hole is about the only way mate. It's just the seal that go on them. Impeller might wear out on a really old one but unlikely.
    The tell tale hole is in the neck of the pump sorry if behind the pulley. Hard to see when it's all in place.
    Darrens was so bad it was a jet stream coming out and very visible. With mine I originally thought it was just a leaky gasket so pulled it off and could make it the water mark coming from the weep hole so world of only got worse and worse.
    What's yours doing?
    Sent from my Pixel 3 using Tapatalk
  16. The Following User Says Thank You to matfew For This Useful Post:
    Hodge (31st January 2020)
