5th January 2020, 12:54 AM
#21
I am glad ARB had free fitting on show special when I bought my front locker, compressor went under drivers seat.
Good write up MB.
The Following User Says Thank You to TPC For This Useful Post:
5th January 2020 12:54 AM
5th January 2020, 11:43 AM
#22
need to be a bit wary if compressor has a thermal cut out switch,
under bonnet temps will render it useless untill it cools down,
5th January 2020, 12:38 PM
#23
threedogs
Good point John. I have the ARB difflock compressor mounted on the chassis rail on passenger side, however it gets a bit of airflow from the location adjacent to the mechanical fan. The under hood temps can get pretty high especially with the Chev. I have not had any issues to date with mine, and suspect the setpoint will be pretty high to cope with the duty cycle these units are designed for.
6th January 2020, 04:30 PM
#24
