8th October 2019, 09:34 PM
8th October 2019 09:34 PM
9th October 2019, 11:54 AM
Mark is the sensor two wire or single wire mate? If single it should just be a simple switch, on (at the set temp) and off. So if you heat some water to the set temp, attach a DMM to the thread and then to the wire, if the switch is working it should trigger at the set temp. Should. Lol.
9th October 2019, 12:42 PM
9th October 2019, 04:15 PM
MB
Thanks Mark mate, appreciated!
Think it is single wire so I’ll give that a go tonight
![](https://s3.amazonaws.com/tapatalk-emoji/emoji106.png)
matfew sparky is in the hills later this evening too so might be able to handball this task to him
![](https://s3.amazonaws.com/tapatalk-emoji/emoji23.png)
Yeah should work in theory. It works on the similar principle to an oil pressure switch, but is activated by heat. The switch is just an earth contact for the fan.
11th October 2019, 08:38 AM
11th October 2019, 12:51 PM
Haven’t had a crack myself yet mate and poor old Matfew has been flat out like a lizard drinking, 4:00am starts the poor bugger!
11th October 2019, 01:06 PM
MB
I have to drop off parts to a customer in Yarra Glen in the morning. I can drop past and take a look if you like.
11th October 2019, 01:14 PM
11th October 2019, 02:02 PM
MB
That’d be awesome, thanks mate
No worries. I'll call you in the morning.
11th October 2019, 07:39 PM
Moderator
Yeah you would test that the same way as a thermostat in a pot. Test to boil.
Check out my Toy -->
Rogue Dung Beetle
