27th September 2019, 10:12 AM
#21
Had to work since Wed night so got a work van to run around in.
So , I Still haven't had a chance to go get the car and sort it out.
27th September 2019 10:12 AM
27th September 2019, 12:12 PM
#22
The Following 6 Users Say Thank You to Hodge For This Useful Post:
Bidja (27th September 2019), Cuppa (27th September 2019), MB (27th September 2019), MudRunnerTD (27th September 2019), Rossco (27th September 2019), Touses (27th September 2019)
27th September 2019, 03:50 PM
#23
Maybe metal pipe acting as heat sink and heat transferred into rubber hose @ connection.
Interested in learning here _ the boost controller (vented) in your set up @Hodge , does it provide a boost bleed to atmosphere so that actuator sees a lesser pressure and wastegate remains closed longer so the turbine spools up low down to for improved boost early?
The Following User Says Thank You to Bidja For This Useful Post:
Hodge (27th September 2019)
27th September 2019, 04:21 PM
#24
[QUOTE=Bidja;791595]Maybe metal pipe acting as heat sink and heat transferred into rubber hose @ connection.
Interested in learning here _ the boost controller (vented) in your set up @Hodge , does it provide a boost bleed to atmosphere so that actuator sees a lesser pressure and wastegate remains closed longer so the turbine spools up low down to for improved boost early?[/QUOTE @Bidja
I think it's a simple boost limiter. Spring inside compresses at set point and lets excess boost out , so as to not push the actuator any further.
The earlier linked versions , are a inline setup I believe . No tee piece. Hose put of pressure side of turbo, through the controller and out onto the actuator.
As for the hose. I really don't know. More so how the hose and the controller gave up in one go.
Prick of a place too. Had to remove the intercooler to get to it. Now to find some quality hose.
The Following 3 Users Say Thank You to Hodge For This Useful Post:
27th September 2019, 04:26 PM
#25
Moderator
Any auto shop will sell silicon hose mate.
Check out my Toy -->
Rogue Dung Beetle
27th September 2019, 04:36 PM
#26
@Hodge good pic thanks.
Yeah the inline controller used primarily to remove initial boost spike have read and to provide more linear boost/spool(low down).
Would replace all boost line hose while at it (pretty cheap).
27th September 2019, 11:00 PM
#27
The Following User Says Thank You to MB For This Useful Post:
Hodge (28th September 2019)
28th September 2019, 09:23 AM
#28
MB
Awesome explanatory picture thanks Hodgey mate, learning every nuffy day me here thanks to your unfortunate expense :-(
As the top blokes above and out there no doubt mentioned too, a positive time to strip ripper TD42 hoses off for another faithful 500,000km we all hope and have seen done too
Already onto it good Marko! Will re-hose the lot after this stint.
Many thanks again to fine gentlemen's helping us out.
Fair dinkum legends as one would say!
The Following User Says Thank You to Hodge For This Useful Post:
28th September 2019, 06:20 PM
#29
Temporary fix, to get the car home. Ran cheapo bit of hose from Supercheap. All good.
Ran the car without the boost controller as per @MudRunnerTD & @nissannewby s suggestion and car ran fine with 11-12PSI (factory specs).
The Following 4 Users Say Thank You to Hodge For This Useful Post:
Bidja (29th September 2019), MB (28th September 2019), MudRunnerTD (28th September 2019), Rossco (28th September 2019)
