I just noticed there's a icon on the screen for it (top left of pic). I double clicked that icon and this is the same as the daily pop up when PC is booted.
That may solve the problem for a while? Let's hope for good.
Go to Start / Run and type in shell:startup then hit Enter
That will open up your startup folder. See what's in there, if that Teams crap is there, delete it.
Plasnart (20th September 2019)
stevemc181 (20th September 2019)
Hey mate, you can do what Steve has mentioned or if you just follow the video I sent you and not uninstall you will be fine. Uninstalling gives Microsoft to reinstall, and reactivate all the services etc. Just follow the vid and do nothing else and your problems should be over
Unfortunately, it still happens. I always ensure everything is closed before shutting down. Also checked that the "re-start application" box was un-ticked. It seems to be happening randomly, about every second or third time I start the PC. ?????? It's becoming very annoying. It's only started happening after the last OS update, but I can't find anyone else reporting it.
So with the new lappy it had 4gb ram installed and I had a spare 2gb ram so installed that
Went into the system properties and is says
Installed Memory ( RAM ) 6GB
(2.70GB Usable )
Whats using up the rest? Im sure it said the same thing when it only had the 4GB installed but not 100% certain????? Whats the go
