30th June 2019, 05:52 PM
Died while driving,wont restart, think its the IP, Help with codes please.
Died under full load passing. Would not restart. Oops 96 3.0ltr Zd30 Direct inj. intercooler
Oil and coolant fine. Disconnected line just after fuel filter, hand pumped fuel into tin just fine. Ok then Hmm. Next cracked open nut on fuel line and cranked , bugga not a drop.
Checked fault codes. by bridging terminal 1 & 8 . Got 7 long 3short , 7long 7short , 9long 5short , 14long 1short
Correct me if im wrong does 7long 3short = 0703 code
So my codes were 0703 , 0707 , 0905 and i dont know what 14long 1short is.
Thanks for any help and or direction
30th June 2019 05:52 PM
30th June 2019, 08:28 PM
Dagwill
Quick Google tells me to check/clean your MAP senspr. Get s scan tool mate. It'll help you sort it out.
30th June 2019, 09:02 PM
Daily Lurker
0-TJ-0
Fyi I have a scan tool and it doesn't work on my di 3L. You need a different scan tool I believe?
The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
0-TJ-0 (30th June 2019), Dagwill (1st July 2019)
1st July 2019, 12:27 AM
Yes bought a scan tool when i had a Terrano, would not fit connection.? Ok so try it on the ZD30. fits the connection ok but cannot make contact with computer.?????
1st July 2019, 07:19 AM
Daily Lurker
Dagwill
Yeah mate, they have an obd2 port, just communicates using different protocols. Someone else here might know what its called? @mudski any idea?
1st July 2019, 08:26 AM
rusty_nail
mudski any idea?
No idea sorry, but code 0703 from memory is what mine had which meant the pump was terminal. The Early Patrols had a OBDII port but the protocols wern't OBDII. The only way to read them is with an ECU talk device.
