Results 1 to 5 of 5
Thread: For Sale in WA - DX grunt - 2005 - 4.2 TDi ute with pod
    WA Wheatbelt
    23 Post(s)
    Item for sale: 2005, 4.2 TDi ute with pod- Ex Telstra
    Price: $30,000 firm
    Condition: Reasonable
    Details:
    At the front ……….
     Warn winch (CE XD9000) with all original Operator’s Manual, Replacement Parts List, Installation Instructions and hand controller
     2 x light bars totalling 520 watts
     Harris Hardcase front diff protector
     2 x recovery points
     LED headlights
     Brand new radiator, thermostat and gasket fitted 21/09/16
     Brand new radiator fan fitted 02/10/15
     New starter motor fitted 07/09/16
     GVM 2” lift kit – 3900kg (coil front, leaf rear) with compliance plate fitted 22/03/16
     Both Tie Rod Ends and Steering Dampener replaced 09/06/15
     Front Swivel Housing and axle seals replaced 26/05/15
     Both gas struts on pod replaced 08/06/15
     Codan 9350 Auto tune base with whip aerial and ‘Knock Down’ base
     Bushranger under bonnet shower unit – fitted 06/05/16
    In the cab ……….
     Child restraint anchor point – with compliance plate
     Dash cams – front and rear
     Reversing cameras display
     Centre roof console with storage, 2 x map reading lights and 2 x USB charging ports
     HF Codan NGT AR radio with radio telephone facilities (currently operational with VKS737 and HF Tel), black whip aerial
     1 x UHF and 1 x HF AM, CB radios
     3 seats – all have been re-foamed and re-covered
     Floor mats
     Switch panel that activates lights, DVD, oven
     Original Patrol Owner’s Manual
    In the pod ……….
     Air vents
     Shelf
     1000w inverter (hard wired)
     DVD player – can get extra sound through your radio
     Travel Buddy - 12v marine oven (2014)
     12v WAECO mounted kettle
     8lt hot/cold water storage
     Interior LED lights (activated by 3 switches)
     2 x 45lt ‘BOAB’ brand fresh water tanks with 2 x electric water pumps
     Smoke alarm
     Security screens on both windows
     Behive pattern, thick, hard rubber mats
     Tie down points
     1 x Anderson plug
     2 x 12v ‘cigarette lighter’ type plugs
     2 x 8amp continuous plugs
    On the outside ……….
     Roof mounted, 12v Sand Flag (illumination switch in cab)
     Roof mounted exterior lighting (6 x LED, 48w Flood beam square lights - 2 each side and 2 at rear – illumination switch in cab) 2016
     Roof mounted 2 x 120w BP solar panels with STECA PR 2020 solar controller
     2 x PVC rubbish bags that fit over rear spare wheels
     30lt fresh water storage
     Ventilated storage compartment containing 3rd battery
     Recovery gear/storage compartments underneath pod (left hand compartment goes full length – right hand goes about half way down due to 75lt aux diesel tank)
     Rear recovery point
     External mobile phone aerial
     Reversing beeper and light - 2015
     2 x brand new spare KO2’s, BFG AT (both have 11mm tread) mounted on back of vehicle
     Tyres on vehicle have approx. 7mm of tread
     6 Sunraysia Rims (2016/2017)
     Tow bar
     2 x diesel fuel tanks (main 90lts aux 75lts – approx.)
     2 x rear steps
    Under the bonnet
     Stock 4.2 TDi engine
    2 x batteries – installed 2017 (3 in total)
     Hot water shower kit purchased 01/02/16
     150amp circuit breaker – manual reset
    Brand new Master Brake Cylinder fitted 17/05/19
     Annex – Affixes to purpose built bracket on left hand side roof of vehicle, and is about 3m x 3m, affixed to the ground using corner guy ropes and tent pegs. The first 1m is made of PVC for showering (with 2 x vents) and the main area is made of heavy duty canvas consisting of one room with a door and window with heavy duty mesh. A skirt has been made up and affixes to the left hand side of the pod.
     Awning – the 5m x 3m awning is made up of heavy duty canvass and goes across the rear of the vehicle and the annex.
    Spares: TBA
    Most receipts have been kept for work done on vehicle since purchased.
    The cab and bonnet do need a paint job.
    Registration plates will be changed to normal number plates, prior to sale
    Is having/has had 350,000km service on Fri 17/05/19
    Location: Merredin WA (half way between Perth and Kalgoorlie)
    Contact: Ross 0408 857 552
    Comments: Engine is stock standard and vehicle is having a 350,000km service on Friday 17/05/19. I'm only selling because I have started my own business and drive it to keep it ticking over and doing tip runs.
    PHOTOS: I'm having issues with pics, so here's the link to my 'Member's Ride'. Please start at the last page and work backwards. Some pics are old. Recovery gear not included.
    http://www.nissanpatrol.com.au/forum...+.....in+flesh
    Regards.
    Ross
  2. The Following User Says Thank You to DX grunt For This Useful Post:
    katwoman (14th May 2019)
    WA Wheatbelt
    23 Post(s)
    Added to the list is a brand new Master Brake Cylinder to be fitted on 17/05/2019.
    Feb 2011
    Shed
    45 Post(s)
    And never been off road
    WA Wheatbelt
    23 Post(s)
    I can almost honestly say in the 8.75 years I've owned it, it's been on the beach twice, a decent sandy track once, and heaps of gravel roads and some short distance sandy tracks, and as most of you know, heaps of bitumen
  6. The Following 4 Users Say Thank You to DX grunt For This Useful Post:
    growler2058 (14th May 2019), MB (14th May 2019), Plasnart (14th May 2019), rusty_nail (15th May 2019)
    Show and shine ute competition winner at least twice also if I remember correctly posts on here too Rossco? Worth putting up those pictures of your top winning setup, super comfy looking......Ladies
    DX grunt (14th May 2019)
