8th May 2019, 06:24 PM
TD42 Water Pump & Timing Cover Coolant Leak Cost
Hey Guys,
So the mechanic confirmed that I have a coolant leak from my water pump, front of timing cover and rear of timing cover on my 1989 TD42.
Now he said its a bloody costly job but never said how much.
I'm not one to tackle it myself so I was wondering how much it would cost to reseal the timing cover both front and rear as well as the water pump? (to get a mechanic to do it)
What are the chances of severe corrosion or anything on it?
Could it potentially make the job cheaper if I removed the engine for the mechanic?
Thanks in advance.
'89 Mav td42 ~ Zoot Zoot mobil
8th May 2019 06:24 PM
8th May 2019, 06:36 PM
Moderator
Sofes
Hey Guys,
Thanks in advance.
Its a pretty basic job mate. @Winnie has a thread somewhere where he has taken all that off. Buy a new water pump and tackle it yourself if you have even half skills mate. we will help you with any questions no probs.
Check out my Toy -->
Rogue Dung Beetle
8th May 2019, 06:38 PM
MudRunnerTD
Oh really? Mechanic made it sound like a pain in the ass to do the timing cover!
Thanks heaps MudRunner!!
8th May 2019, 06:43 PM
The 747
If you are considering removing the engine to help then you are surely skilled enough to take it on.
The only issue I had is removing the cone-lock on the crank that holds the harmonic balancer on. It is a real bastard to get to unlock, start soaking it in wd40 now!
The Following User Says Thank You to Winnie For This Useful Post:
8th May 2019, 06:59 PM
Winnie
Maybe, just maybe I am haha.
Was only going to remove it to either body swap the engine or make it cheaper to do.
Just a look through your thread Winnie, how long did it end up taking you?
I got told you had to remove the IP to get the timing backplate off?
8th May 2019, 07:05 PM
The 747
Sofes
You can leave it bolted to the engine which means you do not have to re-time it.
As for time I'm not really sure as I spent an hour here and there on it over a fair time. If you have all the tools and are more prepared than I was you can certainly do it in a weekend.
