25th March 2019, 05:47 PM
#71
Smart like tractor
altech
Hi Guys, the Big and bloody heavy battery arrived today, hmmm did I mention heavy lol. Did some improvements / upgrades to the battery wiring. Now waiting on the real MPPT charger to arrive. keep you posted regards Alex
Attachment 78214
Attachment 78215
I have a few Questions.
How did you crimp the larger cables?
What the go with that figure 8 cable to the the Negative and what size is the main negative?
96 GQ coil/Cab
08 G6eT
![](image.php?s=12123c148a218d17a8dd27d78fc0c9df&u=1281&type=sigpic&dateline=1483248064)
25th March 2019 05:47 PM
26th March 2019, 07:04 AM
#72
Ben-e-boy
1/ Soldered in like you would a Anderson plug. 2/ 8 gauge wire is neg and it's connected to second battery from that to my rear electric cargo barrier frame work which is grounded to the body of car.
![](image.php?s=12123c148a218d17a8dd27d78fc0c9df&u=6260&type=sigpic&dateline=1353296412)
26th March 2019, 05:03 PM
#73
Smart like tractor
Ah ok. That's why it doesn't look like they are crimped
96 GQ coil/Cab
08 G6eT
6th April 2019, 07:41 PM
#74
Hi Guys, Installed my Real MPPT controller today and works great, it does have a add on Bluetooth receiver that connect's to my phone. in the pic I have changed the wiring again lol regards Alex
6th April 2019, 07:42 PM
#75
And Yes I have MT50 receiver too.
The Following User Says Thank You to altech For This Useful Post:
Yeti's Beast (6th April 2019)
6th April 2019, 08:36 PM
#76
Moderator
altech
Wow the Cargo Barrier is pretty kool mate. What glass did you use? Assume it is profiled right? Well done mate. Fair effort indeed.
Can you post a pic zoomed out a little so we can see it up and down and maybe half up?
Check out my Toy -->
Rogue Dung Beetle
6th April 2019, 08:40 PM
#77
Moderator
![](http://www.nissanpatrol.com.au/forums/images/imported/2019/04/68.jpg)
You have got to fix that though mate, thats junk. You can do much better than that bud. Just say'n
Rogue Dung Beetle
6th April 2019, 08:51 PM
#78
MudRunnerTD
Not Glass, but 10mm plastic . went to dealer, he had a off cut $50 bucks, then I cut it to size
MudRunnerTD (6th April 2019)
6th April 2019, 08:52 PM
#79
MudRunnerTD
Yes did see this after the photo was taken, cheers Alex
MudRunnerTD (7th April 2019)
6th April 2019, 09:08 PM
#80
Daily Lurker
MudRunnerTD
im sure i have seen the equivalent on your beast? come on mate, not everyone is perfect
The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
altech (7th April 2019), MudRunnerTD (6th April 2019)
