Where to put my vacuum line for my compansated pump ?
If you are referring to the A/C Idle up, that comes from a vac operated switch on the firewall, if you dont have that, you'll need one or block the port off
Ahh sorry I hadn't really looked at it yet I assumed it was vaccum,so where from then ? Frome.the wast gste feed ?,I have my boost gauge coming out if my intake but will that affect my boost reading?
Depending on your setup you'd be better off drill and tap a new hole in the intake manifold imo. Too many t's coming from the one spot can end up causing you drama's if something gives up the ghost/leaks.
Leave the waste-gate feed alone, if you really want to tee it off i'd use the boost gauge line assuming they're separate.
