22nd March 2019, 07:13 PM
Where to put my vacuum line for my compansated pump ?
I am installing my 12 mm compensated Ip tomorrow and the old one didn't have one, so where do you get your vacuum from ?
22nd March 2019 07:13 PM
22nd March 2019, 07:33 PM
Smart like tractor
The compensator needs boost pressure not vacuum.
If you are referring to the A/C Idle up, that comes from a vac operated switch on the firewall, if you dont have that, you'll need one or block the port off
96 GQ coil/Cab
08 G6eT
![](image.php?s=e76eb1440716888c7d351a10e741747b&u=1281&type=sigpic&dateline=1483248064)
The Following User Says Thank You to Ben-e-boy For This Useful Post:
22nd March 2019, 08:33 PM
Ahh sorry I hadn't really looked at it yet I assumed it was vaccum,so where from then ? Frome.the wast gste feed ?,I have my boost gauge coming out if my intake but will that affect my boost reading?
23rd March 2019, 12:00 AM
Patrol Guru
Depending on your setup you'd be better off drill and tap a new hole in the intake manifold imo. Too many t's coming from the one spot can end up causing you drama's if something gives up the ghost/leaks.
Leave the waste-gate feed alone, if you really want to tee it off i'd use the boost gauge line assuming they're separate.
23rd March 2019, 12:47 AM
Administrator
I used my waste gate feed but do agree with old mate above with the boost feed if its close to inlet, etc.
