23rd December 2018, 09:03 AM
#1171
nissannewby
A carter 4601 pump is also a good option as a lift pump.
Thanks Matt, I have gone with an Aeroflow that supplies 440lphr open flow and I think has a rated flow of 250lphr at 9psi and a max pressure of 14psi
23rd December 2018 09:03 AM
23rd December 2018, 09:33 AM
#1172
nissannewby
Can be calculated from the hp you want.
At 200rwkw you will want nothing less than 150L/hr. So you would aiming for higher so 200L/hr. So if you have a target hp then it can be approximated.
Matt, out of curiosity, can you send a link or show me how this is calculated?
24th December 2018, 08:01 PM
#1173
Starting to get real, parts finally arriving, CAT and fuel filters. Delivery of system now pushed back to late Jan to allow the entire kit to be trial fitted in WA before sending to me. The S/C has to come from Brisbane, still waiting on the custom 8 rib serpentine pulleys though. Lift pumps due early Jan as well.DSC02240.JPGDSC02241.JPGDSC02242.JPG
24th December 2018, 08:03 PM
#1174
PeeBee (24th December 2018)
24th December 2018, 08:22 PM
#1175
MB from what I am reading a lift pump around the 14=16-20PSI max is what you want to head towards. Some guys in the US run higher without issue, some have problems with electronic error messages, but they are all running the PMD units which we dont have. The pump Matt recdt is rated at 15psi and the aeroflow at 14psi. The Aeroflo is half the cost of the Carter. BD used to supply the carter but have moved away from it and have been installing the Aeroflow, and I know of one guy in WA with the setup i am heading towards that has had the same Aeroflo charging his SC rig for 70,000k without issue and he has cranked it up to the 65mm pulley and not changed the pump.
One thing to remember is just because the pump has the capacity to pump to a higher pressure does not mean it pumps at that unless you have a pressure sustaining loop, which you don't. I have found with my current small BD pump that pre-charge pressure to the Standyne Pump is 9psi at idle and normally around 4-5psi driving and then 0 at WOT but more like 1psi. The pressure is only the system resistance anyway, so if you up the flowrate you will get higher precharge pressure if the pump can deliver it, BUT remember, 90% of the fuel is returning to the tank anyway, so really if you think about it, you just need the demand flowrate to the injector pump plus some nominal precharge pressure to satisfy the demand. I can't see the point of having say a massive over supply if most is going back to the tank. Also, higher pressure = higher current on the pump. I am expecting to see my idle pressure go up as the flowrate will be higher from the new pump, plus i am running thru a 2um filter instead of a 5um, however the filter is now matched flow wise to the pump. I have had both BD and Bullet tell me 9psi is the number, but at what point in the rev range - no comment, but zero at WOT is seem as normal in their eyes, but again, they don't measure it either.
So, another marathon answer!
And Merry Xmas to you and the family.
24th December 2018, 08:53 PM
#1176
Fair call on the Amps thanks mate, hearing that for me!
The Delco Remy 38si Alt in the shed is still awaiting installation too which means I’ll be offing the GQ Alt with rear mechanical vacuum pump and....on goes a planned 12v vacuum pump.
For someone like me who knows bugger all about elecy stuff I keep foolishly gravitating towards it all :-(
Mod’d trucks are like a hornets nest :-)
24th December 2018, 09:30 PM
#1177
MB
I will be looking at the second alternator set-up again, and maybe get that endless air pump finally mounted! I think the Delco is going to be a bit too long for me though, shame as its a great unit for sure. Looking at the alternators avail ex US, there are a heap in the 300amp bracket for the suburban, which is the frame size I need to be looking at .
24th December 2018, 09:34 PM
#1178
MB
Chase up @poindexter as I think he is going that way as well, so will have some choices and a shortlist I reckon.
24th December 2018, 09:37 PM
#1179
All Things Chev
28si Delco might be your go mate.
Front standard mount much easier adaptation than the true tractor block usually mounted 38si beasts which I’m still scratching my head with but will find a way up top one day
EDIT: Whatever you end up choosing old mate, just remember you’re currently swapping back to a Serpentine belt system and many alternators like their Borg stock 38si are clockwise learnt and needed on my NA.
I’m sure you’re all over that as already known with NA V-Belts versus Serpy water pumps etc...
24th December 2018, 10:00 PM
#1180
MB
Can you do something like my setup with the alt on pass side - or is the airbox in the way? If not I think you will have a real challenge as there is no room down low on the drivers side for that monster. Could be back at the jack shaft design, which we can do for sure and long life.
