Bloody hell mate that sucks, has Mike got any ideas?
If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
Ok serious note here.
Is it turbo'd?
If so check the turbo to intake pipe for a lot of oil.
You may have simply done a seal and flowing oil into the engine.
Wost case cracked piston, bore etc.
Either way get onto it before you hydraulic it and punch the rod out the block...
I am hoping against hope that the bores are all ok......... just shot rings etc
if the bores are cactii, dunno what to do then
but I will wait until I get off my fat bum after Xmas, and start stripping it down, have engine stand & crane available for when I go to pull it out, just need to clean the car port more for more room to move
Bigcol (19th December 2018)
Try this before you get the engine full monty. https://www.youtube.com/watch?v=f9K0UFdEn_M
see the bit at 3.16, where it is spraying the crap out of the injector holes.....
thats what mine is doing when you take the rocker cover cap off................ while its running
chugg chugg chugg
I'm hoping for your sake that it is stuck rings, so there is just massive blow past the cylinders. But having the oil way to full would be like the bottom of the pistons smashing into concrete on each down stroke. OUCH!!
