Baby steps good man, you’re a Legend!!
Get the big screws on top first then try and close the bonnet, decisions can be made then......and breath
Yeah I know, just trying to get things orderly in my mind as i only get small chunks of time usually for mods. This one will be a little different. I was hoping to do the engine pulley swap over the Xmas break, but looks like the custom 8 rib serpy pulleys might miss the xmas deadline. If thats the case i will do the body lift instead and chew on those lemons. Speaking with @MudRunnerTD today about the process, he assures me its not too big a job, one person for a day should knock it, only the rear mounts require some access surgey to get to the bolt heads - checked it out tonight riefly and does not look too bad.
MudRunnerTD (11th December 2018)
Please please Philstar do take some roof rack weight off then mate if going up that extra 1” body higher. I personally would try everything else but that first honestly mate!!
PeeBee (10th December 2018)
I hear you, - but - I will see what goes, as really i have to be able to get it inside the garage as well and dont want to have the stuffing around of dropping tyre pressure for that!. I dont carry the galv box anymore so just roofrack, solar panel, 14klm of copper cable and some antennas, should be ok, but hear you load an clear.
MB (10th December 2018)
Great to hear mate, and truly honestly only trying to pay back a whisker of the best guidance off site you’ve always kindly given myself and closest!
COGravity coin would be best IMO spent on keeping the old faithful GQ beast low and slow with a set of GU stronger/wider axles my friend
So where are you going to sit when I get the garage to handle the height of the portals? Hope you are not going to restrict me to the likes of jells park or Chadstone shopping centre? Yes they are 100mm wider, but 4" taller. Anyway. I am in no hurry for GU axles, mine have lasted just fine to date with the driving style i adopt.
All I can say old mate is that two high horsepowered TD42Ti GQ’s live on the next hill over to ours. One is a lightweight usually solo driver with stock axles and super lightweight rack. Other is a family man with much baggage atop so opted for wider COG axles. Both are neck & neck comparatively acceptable IMO :-)
