23rd November 2018, 02:46 PM
Fireblade
salim do you have a wiring picture of your head unit, something that tells you the purpose of each wire from the plug?
Hi mate not sure if this is what you mean.
23rd November 2018 02:46 PM
23rd November 2018, 02:48 PM
Fireblade
if you do need a reverse signal for the head unit these is a yellow wire in the left hand kick panel that i used to trigger the head unit.
im sure is was a solid yellow wire just use a test light and prob which wire lights up with reverse there should be one in the left hand kick panel
i have a 2008 wagon right hand drive. yours may be different
Thanks for this mate sorry but what do you mean by kick panel? Yep same car as yours.
23rd November 2018, 11:57 PM
I'll give it a go thanks mate. No idea it's some chinese eBay unit which is performing quite well for $250 so far hahaha
the evil twin
Yes... or at least insulate the Head Unit end.
Personally, I would find out which wire is teh Rev Cam Trigger on the head unit and connect it up.
What brand/model is teh head unit?
Sent from my ONEPLUS A6000 using Tapatalk
24th November 2018, 12:05 AM
I am he, fear me
Salim
On the pic you posted... Plug A is the plug in question and one of the wires will be labelled Rev Cam or similar.
If you put 12 Volts on that wire it will trigger the Head Unit to display the "R-Cam" video... that is what the red wire is for that is part of the RCA lead.
Salim (24th November 2018)
24th November 2018, 12:11 AM
Oh well there's my problem I didn't even use that bunch of wire lol. I'll get that sorted and post an update. Thanks a lot mate.
the evil twin
24th November 2018, 09:10 AM
Sounds like your on a good track now, the kick panel is in the left hand side of the left hand front foot well.
You’ll have the pull up the scuff trim and then pull out the kick trim, there’s a screw holding it in as well.
The Following User Says Thank You to Fireblade For This Useful Post:
Salim (25th November 2018)
25th November 2018, 12:57 AM
#17
Do you mean left side as in the passenger side or just the left side of the foot well in the driver's side?
Fireblade
26th November 2018, 10:35 AM
#18
on a right hand drive car look in the lefts side of the passenger foot well
Salim (26th November 2018)
