I'll grab a quick pic tomorrow arvo for you mate.
The bolts should all be very obvious though.
MudRunnerTD (3rd December 2017)
hi winnie
how long did this take
anything youd recommend when doing this again
i may be doing this soon
my engine has me dumbfounded as it has 55mm cranknut,oil drain in sump water lines into turbo from thermo housing but mine has a low engine number td42091600 1999 model
thanks benny
i thought with the factory 1" oil drain, and bigger crank would exclude this being na
finally found that a 55mm crank and block drain will generally mean its a t engine
