Hey just wondering on your guys' thoughts.
I've found a 1993 GQ Patrol TI with a tb42e engine and 320,000k's. https://www.gumtree.com.au/s-ad/stot...ail/1198031338
I went and had a look at it, the inside door trims are missing, seats are ripped, there was oil around radiator under engine block, on top of diff and around front brakes. After jump starting it, the engine sounds good, no knocks, no visible radiator leaks, all fluids were fine except the owner mentioned it needs steering fluid, engine was reconditioned in 2014 and I couldn't find a spot of rust.
So it'll need new seats, door trims, battery and steering fluid.
