31st October 2018, 08:08 PM
#1081
Administrator
Winnie
Yeah I've got the o rings, I'm gonna install the pump and have both vac pumps running into the canister on the drivers side.
Gonna be very easy to run a vac hose from the timing case mounted pump there, and there are already solid vac hoses going across the firewall so I will just go from the alternator to one of those solid hoses and from the other end of that to the canister.
Darren reckons he also had a good improvement just from moving the canister over.
Ok cool! It's a hard line across the firewall so vac distance shouldn't make a difference or very minimal but either way mate go for it!
Just make sure you utilise double vac though mate.
31st October 2018 08:08 PM
31st October 2018, 08:18 PM
#1082
The 747
AB
I actually have a second canister on the shelf at home and could run double canisters lol. Could even seperate the clutch from the brakes and have them on their own pumps.
31st October 2018, 08:31 PM
#1083
Administrator
Winnies 747 TD42 GQ
Winnie
Yep I've always wanted to experiment with larger canisters/storage etc...
31st October 2018, 09:42 PM
#1084
Rossco
Flywheel either rattle gun or breaker bar. Just need to wedge a screwdriver or prybar into one of the flywheel teeth and lock it against a dowel i think from memory. Kindof a fun job when you've only got two hands lol. . .
This is how I've done it in the past.
Winnie
Yeah problem there is because the engine is just sitting on a tyre it wants to turn onto its side. Would probably help if I could get somebody to hold onto it.
Rest the engine on his side....
Or, you should be able to wedge something between the teeth and the ground. That's only if Nickos monster doesn't work.
Seems to be coming together nicely. ![](https://s3.amazonaws.com/tapatalk-emoji/emoji106.png)
The Following User Says Thank You to jay see For This Useful Post:
Rossco (1st November 2018)
31st October 2018, 11:08 PM
#1085
Moderator
Yeah i have removed the hard double fuel line and the vac line off the fire wall. Pointless plumbing. Moving the canister to the drivers side made my clutch so light i didnt think i had one!!! Cant believe the xhamge.
Check out my Toy -->
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
Hodge (1st November 2018), Winnie (1st November 2018)
1st November 2018, 07:26 AM
#1086
Administrator
MudRunnerTD
Awesome!
Are you running double vac though?
1st November 2018, 07:27 AM
#1087
The 747
AB
Awesome!
Only the kool kids run double vac haha.
I got the vac pump and flywheel today. Need to get the flywheel machined up and a hose made for the vac pump.
1st November 2018, 08:31 AM
#1088
Yeah was thinking that, can join the double vac wanker club now lol.
You want me to drop in at home or work tomozz, should be coming through mid morning.
1st November 2018, 04:55 PM
#1089
Moderator
Wankers indeed. Nah single vac pump. I think the improvement us a co sequence of the canister volume is very close the the booster and isnt reatricted by 4m of 8mm tube
Rogue Dung Beetle
growler2058 (1st November 2018)
1st November 2018, 05:57 PM
#1090
Administrator
MudRunnerTD
Yeah ok, it's just Winnie is still using his Alt vac too so he still has to run that to the firewall with rubber hose and across the firewall hard pipes to rubber hose junction along with a custom pipe from T engine to the new cannister location which no doubt he'll use rubber hose too so yes huge improvement with double Vac but very long lengths of rubber hose that's all.
This is all minor though so all good. That's why for Winne's double Vac set up he should leave it all as is IMHO, block off T vac pump for now until he finds OEM line but all good, both will work fine.
