Page 106 of 116 FirstFirst ... 104105106107108 ... LastLast
Results 1,051 to 1,060 of 1157
Thread: Winnies 747 TD42 GQ
  1. #1051
    Well done mate, good to see you getting through it!
    Cheers Nicco! Hey with the sticker you print can you only do vinyl or can you use other materials?
  2. #1052
    195 Post(s)
    Hey winnie do you want me to drop off the pump timing kit on friday, I'm heading through to Coota so can if you want.
  3. #1053
    That would be awesome mate! Can I borrow your clutch aligning tool as well?
  4. #1054
    195 Post(s)
    Oh yeah knew I'd forget about that, I'll pack it tonight.
  5. #1055
    Thanks mate that's a big help!
    Just need to work out how the hell I am going to get the flywheel bolts out of the old motor. I need to get the sandwich plate.
  6. #1056
    331 Post(s)
    what do you need to make that happen mate?
  7. #1057
    I think the only option is going to be an effing big rattle gun. Mine won't budge them and with a big breaker bar it just want to rotate the engine onto its side because it is not secured.
  8. #1058
    Can someone confirm that this is the oil feed port for the vac pump? Does the vac pump have an oil drain? I can't see where it would go into the block.
    Edit: I can see the pump would just drain into the timing case.
  9. #1059
    587 Post(s)
    The vac pump does not need any feed or drain. The pump mounts to rear of timing case and uses oil in there to lube gear.
  10. #1060
    Hmm you sure? It definitely drains into the timing case but I reckon it needs an oil feed.
