22nd September 2018, 02:18 PM
Help - Water leaking 4.5 rear of firewall
Hi Guys, my old girl is leaking water bad near firewall heater hoses, but can't see where it coming from due to the 4.5 engine bay . water is streaming out under engine power, My son doesn't think its the small heater hoses . look on pdf gu manual, no diagrams whats their. any ideas or photo's guys what i'm looking for regards Alex
![](image.php?s=5a7f394bc9003310ba4a1ff6d2d82595&u=6260&type=sigpic&dateline=1353296412)
22nd September 2018 02:18 PM
22nd September 2018, 05:21 PM
23rd September 2018, 11:41 AM
Hi 3dogs ,can't see due to firewall , is there a welch plug at the back off block near firewall regards Alex
28th October 2018, 12:12 PM
Hi Guys, Maybe found leak at back of block near fire wall, it looks like a Welsh plug as can see from video. Maybe ????
The Following User Says Thank You to altech For This Useful Post:
mudnut (28th October 2018)
28th October 2018, 12:54 PM
28th October 2018, 09:02 PM
What's the story? Welch plug, garden hose left on under bonnet, fire suppression device????? Hope its not a major for you to resolve.
altech (29th October 2018)
29th October 2018, 07:38 AM
The water is not coloured like coolant should be. I take it you just top it up with plain old water? Anyhow a leak that bad looks like a welch plug to me.
29th October 2018, 08:22 AM
mudski
Hi Mudski, Coolant gone long ago. I had the water hose topping up the radiatar and it was coming out the hole. Can you tell me is there ment to be a welsh plug at the end off block . Can't find any diagrams on this area. cheers Alex
29th October 2018, 11:12 AM
Not sure myself mate but I assume there would be. Use a little mirror and check. Is it from the block or head you think?
29th October 2018, 11:15 AM
