1st July 2010, 09:48 AM
Information on TB42s extended rotor button
GQ Patrols fitted with the TB42s (carby model) run a points type Distributor which have an overly large air gap between the rotor button itself & the distributor cap.
This has been well none & documented to course problems. Some of the side effects of this large air gap is missing at idle & missing under load. This problem is amplified when running LPG but not exclusive.
To combat this problem a company in Melbourne developed an extended rotor button for the TB42s points type Distributor which has been met with great success.
Here is some pictures of the re-developed rotor button & you can find contact details at the bottom of this post.
Extended rotor Button from Performance Ignition Services. 03 98723644
Price is $80, inc GST.
They do changeovers, at $35 plus $45 deposit.
Overnight freight is from $11 if required.
http://www.performanceignition.com.au/
Paul
The Following 3 Users Say Thank You to patch697 For This Useful Post:
MarkGQ (25th January 2013), taslucas (17th September 2011), YNOT (19th January 2011)
1st July 2010 09:48 AM
3rd September 2010, 11:32 PM
Do they modify the standard one ?
3rd September 2010, 11:43 PM
Yep thay do thats why thay work so well
13th September 2010, 12:41 AM
were abouts are these guys?
13th September 2010, 12:51 AM
Russell1974
At 47/41-49 Norcal Rd Nunawading VIC 3131
Location map
Paul
13th September 2010, 10:43 PM
Well worth the money ,
I noticed a difference in how smooth my Maverick ran as soon as i fired it up.
90 maverick LWB 2" lift,General Grabber a/t
92 Coil Cab 3" lift, kl71 33"s n/a td42
19th January 2011, 10:08 PM
i am from turkey, how can i buy?
19th January 2011, 10:13 PM
#8
Contact them on their website and see if you can arrange to have one sent to you.
Tony
4th May 2011, 09:09 PM
#9
I also found a small improvement in power (but not economy that I can measure), and the missing at idle has virtually disappeared.
Chris
'88 LWB TB42 Auto Dual Fuel 72/90lts 3rd gear Trans Lock-up 2" Suspension Lift Piranha Dual Battery
4th May 2011, 09:49 PM
#10
adamsc57
Chris
thats exacly what im after!!
