Page 20 of 24 FirstFirst ... 1819202122 ... LastLast
Results 191 to 200 of 233
Thread: RB30 Facts, Figures and Helpful Hints
  1. #191
    Patrol Guru
    Jul 2014
    6 Post(s)
    @mudnut on your snorkel post earlier (page 13 from memory). Have you done anything to seal the top of the airbox to the carby? I know there's a rubber seal there, but IMO it's a weakpoint and whilst I haven't had issues yet, it's next on my to do list (make up an airbox so I can have a silicone bend clamped to top of the carby).
  2. #192
    81 Post(s)
    Just a large washer and a piece of inner tube.
    The real worry is the pre-heat flap inlet and vacuum diaphragm casing.
    I ran a bead of silicon on the top and used a reducer and plug on the inlet but found it was too restrictive in cold weather with the plug removed.
    I will probably get a full sized aluminium plug machined up and seal it with a fine bead of silicon so it can be removed in winter.
  3. #193
    Patrol Guru
    Jul 2014
    6 Post(s)
    Think I'm going to do away with the airbox completely and move to a patroldocta style one or similar. Have heard most people block off the vac lines from carby to airbox with no ill effects, anyone know what they do/run/change?
  4. #194
    81 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    Dom has posted the vacuum circuit earlier in this thread.
  5. #195
    Patrol Guru
    Jul 2014
    6 Post(s)
    @dom14 you still around here mate?
  6. #196
    81 Post(s)
    Ok, all you Dirty thirty owners. Time to check and re-torque the crankshaft pulley bolt!! 152 nm or 112-113 ftlb.
    Take off the stone guard. Unclip the radiator shroud extension piece and it is easily accessible.
  7. #197
    81 Post(s)
    For those who want to build a high-powered beast out of the RB block. https://www.youtube.com/watch?v=KF1iTh-2u3E
    https://www.youtube.com/watch?v=TS3fFLg2QfU
  8. #198
    Patrol Guru
    Jul 2014
    6 Post(s)
    Anyone have an aftermarket Airbox in their rb30? What do you do with the vac lines that feed into the stock one? Plug them? What do they all do?
  9. #199
    Patrol Guru
    Jul 2014
    6 Post(s)
    bumpity bumpity bumpsalot
  10. #200
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Post #56 doesn't help?
