19th August 2018, 11:32 PM
Scan tools
Hey guys new to the forums.
I own a 3L DI gu patrol and having some issues with it running. I have used a foxwell NT200 and also a Actron CP9576 but they dont seem to work on my 3l DI. Does anyone know a good scan tool to use or to buy that can actually work on a DI? Cheers, this is my rig atm 39467585_275708943247578_4118958973569204224_n.jpg
19th August 2018 11:32 PM
20th August 2018, 08:27 AM
Dunno if 4x4 SC still sell one, but theirs works on a Di.
20th August 2018, 07:39 PM
mudski
Mark, was this the EDS tool from Berrima Diesel _ OBD11 compliant?
Craig Mc
Craig, the ECU Talk scan tool is widely used for non-CRD ZD30DDTi. Check the diesel compatibility list on the attached link. It also explain the configuration of the Nissan Consult protocol (14 pin connector) pre CRD.
http://www.ecutalk.com.au/diesel.aspx
These have USB interface also.
20th August 2018, 08:51 PM
Bidja
Ahh yes it was too. ECUtalk as you mentioned is the correct tool for the earlier Di's.
20th August 2018, 08:53 PM
I have a Nissan Consult for pre 2000 Patrols together with ECU Talk Software.
See Screen Shots here http://www.ecutalk.com.au/screenshots.aspx
Free to good home.
Pick up in Pakenham
The Following User Says Thank You to Bob For This Useful Post:
21st August 2018, 10:15 PM
Hi Bob, would this work with a 2000 GU with a 4.8 petrol eng? Mine is surging and flat spotting just off idle & is intermittent & would like to do live data. Thanks - Leigh
22nd August 2018, 09:02 AM
LeighC
@LeighC
Yes I believe it will.
If you want to bring it around it will take 5 minutes to hook it up to test
Regards
Bob
22nd August 2018, 04:14 PM
Thanks Bob,
I have been told I need Consult II, I have an OBD2 plug under the dash but it doesn't appear to talk the later language.
Its a bit hard to bring it around as I am in Northern Vic above Shepparton, I do know a guy who lives in Dandenong that I may able to get him to pick it up, is that close to you?
If it doesn't work he could drop it back, he drives a car carrier & comes up regularly. I could send you a prepaid postage bag would that be OK?
I would like to get to the bottom of it really because my next step is a new TPS & that is expensive for an auto trans. as you have to buy the whole throttle body with motors & so forth, the vehicle has done 300K so it could be getting worn in the resistive pots. I do not have a check engine light on & the Nissan dealer cant find anything, have fitted a new MAF sensor & 2 oxy sensors, done the valve shims, set the timing, done the 3 throttle relearns & still has this intermittent lean mixture just off idle & it even mucks the auto changes up when it happens, other than that it drives perfect 90% of the time.
Cheers for your help- Leigh
24th August 2018, 03:34 PM
Bob if it doesn't work with @LeighC I'll grab it, my Patrol is what you had.
