Here’s a copy & paste for us Umans!
“The question that helps us all most is what do we need, not what do we deserve”
Heavy man, just plain heavy
You reap what you sow, so by default you get what you deserve, as against what you might need - hows that twisted around!
MB (17th August 2018)
Is this about cushions again?
Too easy old mate, your problem google solved! Load the bed up with ebay purchase #889 emoji pillows to share together her love of cushions
Not so much angry more like pissed off the timing is out on the zd30
Didn't know you had to lock the ring gear before taking the pump out
ah well lesson learnt start again Monday will just pull a part the front of
the motor to get to timing gears to line up
any one have an idea on how to undo the crankshaft nut .......easily
Bugger Roofy sux mate. Not sure on the front crank nut it's a big bugger, looong breaker bar or bloody good impact? Why does the crank nut have to come off?
If eng out, lock up flywheel and you need to give the nut a sudden knock force with hammer or lump of wood using a ring spanner or socket & bar what ever U are using. A sudden impact force has far greater effect than just applying pressure/torque. If engine is in veh & transmission connected, locate breaker bar against something solid and some give the starter a flick. Or try just putting in 1st gear, get someone to put foot on brake/hand brake(all) and give the ring or socket/bar a sudden knock like when locking the flywheel. Rather use a socket and breaker bar.
Sir Roofy (18th August 2018)
Lachy destroyed iPad screen number 5!
Genuine question as I'm slowly losing my shit doing this on my own folks. Crazy autistic child proof demon child iPad covers?
Genuine frigging question as I'm at a loss now!
