Results 1 to 10 of 12
Thread: new member intro 99 4.2 gu
    Jun 2018
    hi all
    I just recently purchased the old girl and now have a few months travelling oz with 2t caravan,the whole trip I have been reading up on turbos and mods that will help extract more power and am fairly confident a bw 6758 should do the job and will also fit a front mount intercooler.
    Also will be looking at a new clutch kit
    so anyone with exp with similar set up your info would be much appreciated
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Hello and welcome to the forum.
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    584 Post(s)
    Welcome to the forum mate and feel free to ask any questions.
    Yep, I have the 6758 with a well built 12mm pump and FMIC and its a perfect set up for the TD42.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day mate and welcome to the forum.
    Jun 2018
    thanks for replies
    anyone changed out the warn winch in factory bar it's quite old and cable and solenoids need replacing would you replace or repair the old warny
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Gday mate...welcome aboard.
    I dont know much about Warn winches but ...
    Chuck a question over on the electrical thread on the main menu bro...plenty of keen critters on there.
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
    Jun 2018
    wow time has flown by
    ive added 30k to the truck and shes performed well in all offroad terrai
    shes been the creb, the old tele track, kimberly's and to steep point to name a few.
    unfortunately shes also gained afew leaks 3 oil and water around the front and a slight seep from the head gasket at the back
    ill have to pull timing cover off and front plate soon to sort out the front leaks oil and water can leaking in 2 different spots
    water looks to be the orings or front plate
    but the oil has me scratching my head, doesnt look like the crank seal and the spray is mainly near the back cover to th ip
    ive bought a whole load of seals and gaskets hopefully this sorts the front.
    any advice would be very helpful
    shes booked for compression test and leak down in 2 weeks
  10. #9
    Jun 2018
    so compression is all within range quite suprised with 400 on the clock
  11. #10
    Jun 2018
    also fixed a leak when changed the oil and redone the seal on the ip cover
  12. The Following User Says Thank You to jjjag For This Useful Post:
    GQtdauto (30th December 2018)
