Page 836 of 1056 FirstFirst ... 336736786826834835836837838846886936 ... LastLast
Results 8,351 to 8,360 of 10552
  1. #8351
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Cleaned back some corrosion on chassis rail weld joint and repainted.
    Fitted Out Back Ideas "T"recovery point (good for lift point as well), thanks John.
    Also fitted Billy Goat bash plate.
    Some minor mods to fit up but all good and happy.
  2. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    GQtdauto (6th May 2018), MB (6th May 2018)
    196 Post(s)
    wired up fans, all good, no smoke testing took place, all runs as designed, grill back on and back into the garage for another week of rest!
  5. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (6th May 2018), MB (7th May 2018), Yeti's Beast (8th May 2018)
  6. #8353
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Installed new wiper blades....in case it ever rains here in W.A.
  7. The Following User Says Thank You to Mc4by For This Useful Post:
    GQtdauto (8th May 2018)
  8. #8354
    Be careful of those bash plates mate. A few members here had them and bashed them in enough that it was fouling on the drag link.
  9. #8355
    Jul 2017
    37 Post(s)
    Thanks mate, been off line this week. Yeh not a lot of clearance in there, will keep an eye on it. They must absorb quite bit of energy before fouling occurs but do appreciate the heads up. Do the other builds like the Patrolapart supplied ones, do they provide a lot more clearance or are you just commenting generally against the use of them ?
  10. #8356
    Patrol God Stropp's Avatar
    31 Post(s)
    Waved goodbye to it as my brother drove away with it
  11. The Following 4 Users Say Thank You to Stropp For This Useful Post:
    Avo (13th May 2018), Clunk (13th May 2018), MB (13th May 2018), Woof (13th May 2018)
  12. #8357
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Took it for a run along the Brunswick Challenge Track to test the new wiper rubbers I installed.
  13. The Following 2 Users Say Thank You to Mc4by For This Useful Post:
    Clunk (13th May 2018), MB (14th May 2018)
  14. #8358
    Just generally... The plate that bent were of 6mm steel plate too. I just bought a Superior Engineering 4340 comp spec drag link and tie rod. Lifetime warranty against bending it so it was a no brainer....
  15. #8359
    Dec 2017
    NE Melbourne
    A couple of months ago I scored some 6" Kenwood speakers from Supercheap that were marked down from $70 to $30 and then I got another 40% off so they were only $18 per pair. I also bought a $10 set of plastic tools for removing door trims. Today I replaced all four of the stock speakers (Clarion branded with paper elements) with the Kenwood ones and I'm happy to say that I managed to do it without breaking any of the door trims or the "Christmas Tree" attachment thingys. It took about 45 min for the first one as it took me a while to work out how to get the door trims off but it got easier from there and the last one only took about 20 min to remove trim, remove speaker and cut existing connector off, solder on new speaker, install speaker, replace door trim). The sound quality is so much better and I can turn it all the way up on the stock head unit without it distorting. Now I just need to keep an eye out for a new head unit and I am still deciding if I am going to add an amp as well.
  16. The Following 2 Users Say Thank You to Big Gags For This Useful Post:
    GQtdauto (13th May 2018), MB (14th May 2018)
  17. #8360
    Jul 2017
    37 Post(s)
    Yeh, have spoken with them and yep they say they don't bend and covered under warranty, this is fair enough. The old pitman arm steering box would get a pounding if there was that much kinetic energy needing to be dissipated..
    Each to their own, but IMHO, I prefer a plate in this location to provide some general protection and be used as a deflector of sticks/logs from being thrown up in to the drive pulleys and fan belt region, especially whilst reversing out over crappy ground cover situation.. Has happened to me once and had a hell of time had removing a stick..
  18. The Following User Says Thank You to Bidja For This Useful Post:
    mudski (14th May 2018)
