Results 11 to 20 of 38
Thread: Best way to remove dent on fold rear quarter
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    if only you were close ...
  2. The Following User Says Thank You to garett For This Useful Post:
    AB (14th April 2018)
  3. #12
    587 Post(s)
    Yep, had a careful crack at it, paint started cracking, THAT'S IT, IT'S STAYING AS IT IS...DAMN IT!
  4. #13
    It's OK mate. You've seen my rear door, you sorta get used to it.
  5. #14
    Jan 2015
    19 Post(s)
    no no its called an easy beat and bog and paint.
  6. The Following 2 Users Say Thank You to garett For This Useful Post:
    AB (14th April 2018), GQtdauto (15th April 2018)
  7. #15
    195 Post(s)
    Take it to Lenny, he'll sort it out . . .
  8. The Following User Says Thank You to Rossco For This Useful Post:
  9. #16
    Dec 2015
    WA
    5 Post(s)
    They're not dents, they're memories.
  10. The Following 6 Users Say Thank You to GeeYou8 For This Useful Post:
    AB (14th April 2018), Avo (14th April 2018), GQtdauto (15th April 2018), jay see (14th April 2018), MB (15th April 2018), Rossco (14th April 2018)
  11. #17
    587 Post(s)
    You should fix that mate, I would so trade you dents as the rear quarter is a nightmare!!!!
    Find a barn door, spray it brother!
  12. #18
    331 Post(s)
    Seriously mate, bring it over and we can have a good crack at it. It really is a 2 person dent mate. some pressure from inside and a smooth face hammer on the paint side will make it considerably better than it is.
  13. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  14. #19
    587 Post(s)
    That dent is not coming out without paint damage.
    Removing the inner trim will give you access to get in there, but since the fold/crease line is damaged, it will take a lot of beating, and pulling to get it straight again. To get it straight properly, the paint needs to be taken back to bare metal.....
    Begone with your logical and correct comments too...lol
  15. The Following User Says Thank You to AB For This Useful Post:
    rusty_nail (15th April 2018)
  16. #20
    Legendary happygu's Avatar
    If you want to get it done, how much would you pay to neaten it up a little, as I know a good panel beater that will usually do it a bit cheaper if there is no time pressures and he can use it as a fill in job?
